MikyD
- MANCHESTER
- Golf gti mk7 pp
Perfect, thank you, great siteTry to login with Telegram.
Posted this in another thread but wondering if you might have any advice -- I had my MIB2 updated from 0890 to 0879 (still makes no sense why the numbers don't go in order, but whatever.) Afterwards there's a setting missing called "display time in standby mode". Any idea how to get it back?That's about right. You can only install (officially) firmware from within the "family". Unit with 02xx will only accept 02xx firmwares.
where did you get 879 from? can you share a link?Posted this in another thread but wondering if you might have any advice -- I had my MIB2 updated from 0890 to 0879 (still makes no sense why the numbers don't go in order, but whatever.) Afterwards there's a setting missing called "display time in standby mode". Any idea how to get it back?
Had it done at the dealer under warranty. Gave them this TSB: https://static.nhtsa.gov/odi/tsbs/2020/MC-10181426-0001.pdfwhere did you get 879 from? can you share a link?
Given I lost the ability to turn my radio off after the update, I’m gonna say no lolAre there any advantages to updating software other than better stability? IE, new features, better response time, things like that.
Any word on whether 0867 is newer than 0879?mibsolution.one
Also there's a huge knowledge database at mibwiki.one
Extract downloaded package before copying to SD card. And copy it directly to SD, not into some folder - so there’s metainfo2.txt file in the root directory.Hello,
So I followed Mr Fix's video in updating the software in my Golf.. I installed the firmware onto an SD Card (FAT32) and have put it into the SD slot in my car. When I go to 'Software Update' the SD card button is not highlighted. I then go via holding the 'Menu' button to update the software, it statest that there is no source with updated software on. Have I gone wrong somewhere?
mibsolution.one /MQB_Solution/_pre MIB2/MSTD/VWHi, another newbie here.
I'm not sure which firmware update is right for my Golf as I can't find anything that starts with MSTD on mibsolution.
Installed SW Train Version: MSTD_EU_VW_P3163
Installed SW MU Version: 0421
Part Number: 5G0035874
Any help would be appreciated!
Thanks!
