MIB2: Export your iTunes library to SD card or USB stick for perfect functionality
KevinC
'19 Golf R, '21 M2c
When I first bought my '16 Golf R last June, I put an iPod Nano semi-permanently in the center cubby, thinking I'd found the ideal solution for having complete access to all my music and playlists all the time, without having to plug in my iPhone and use CarPlay. This solution works quite well, however there are a few downsides. One, I don't want to leave any iPod hooked up in my car 24/7, especially during the summer months here in Phoenix, when car interiors reach surface-of-the-sun-like temperatures. Second, you lose the "Coverplay" functionality, which I think a lot of people don't even realize is a thing as it's not documented in the manual. It's a really cool feature. More on that later.
Below is the file layout you want on your SD card or USB stick. Later I'll talk about how I exported mine via a MacOS program called Export for iTunes, which sells for $7.99 in the App Store. Very reasonable price for all its capabilities.
Format your media as ExFAT. No matter how you move your files to your media, arrange them like this:
The shot above shows my m3u playlists in the root directory, and a "Music" directory, under which all your files will be stored like this:
I exported my files with track numbers added, though they aren't necessary for the songs to play in the correct order - the id tags on the files themselves identify where they belong. I also exported the album artwork in its own file, though again this shouldn't be necessary as the artwork will be found with the individual tracks.
Here's how I exported my playlists & albums using Export for iTunes as mentioned above:
I checked only the playlists I wanted to bring over - leaving out iTunes default stuff like "all music", "no lyrics" etc. The options I chose are shown. I see one error in that screenshot - you want to include the playlists, not just the files as I have checked here. Whoops. They will be exported to the root directory.
Next I exported all my albums, as shown here:
No converting going on here, what you want is the original AAC (m4a) format.
Another gotcha on the (first) above shot - I redid the export without the "save m3u files in the same folder with tracks". If you do this as shown, all those playlists for each individual album will show up as playlists in your library view on your MIB2 screen, which is completely redundant, and they're not needed for the albums to play correctly. So don't do that, uncheck that box.
Yes, all this can be done manually, but it's pretty tedious, and this program is cheap IMHO at $8 and totally automates the process. It also has a bunch of other capabilities like converting formats that aren't necessary here but might be of use to you at some point.
I mentioned Coverflow - you get this feature when using SD card or USB media, but it does not work with an iPod connected, for whatever reason. While playing music, when you move your hand close to the screen and the menu labels appear, your album art also fan out like this...
Tap the album cover, and voila, you get this...
Now you can simply swipe through your albums, and go directly to one by tapping on the cover you stop on. They are in alphabetical order by album title, and there's no way to sort them differently, unfortunately - I'd prefer by artist - but it's still really cool and immensely useful IMHO.
Free up your USB port and go SD card, it's slicker than snot. I use a Class 10 card from SanDisk. Any non-crappy card at that speed should work fine.
Stonejet
Colorado
That's a great write up.
I've had my '17 Golf R for nearly a month now. Initially I did basically the same thing with my iTunes library but I wasn't enthused about the sound quality of the mp4 format. So I downloaded a piece of software called XLD (free) and used it to rip all of my CD's into FLAC format. I then indexed all of the artists and albums into separate files on a large external drive and then copied that big file onto an SD card and plugged it into the car. Definitely time consuming but all of the features on the MIB2 work beautifully and it sounds terrific.
IMO the higher quality FLAC format really brings the Fender system to life. I highly recommend if you've got a few hours to spare to set it all up.
P.S. I use a Mac.
Bay Area Smoke Hell
DVP Spektrm, MK4 R32
P.S. I use a Mac.
I use FLAC (on USB/SD in car) or Apple Lossless (in iTunes/on iPhone) exclusively anymore. Life's too short to lose quality of what I'm going to listen to by using lossless media.
Can I ask how you handled album art for your FLACs?
Stonejet
Colorado
Agree on the sound quality issue. Some people say they don't notice a difference between lossy and lossless. I do, even in a relatively noisy environment like a car, and that's what matters to me. As I said above, it really makes the system come alive.
As to the album cover art, XLD takes care of it. The software found the metadata for the majority of my CD's. In the case of the ones it was unable to find, I just uploaded an image of the cover art (I used files 700x700 or smaller) into the space provided. It works really well and has a short learning curve. Even though it was free, I plan to donate. I'm sure I'll continue to use it.
I have to give you credit RTB. I got started on the whole FLAC tangent because of a post you made at one point. So thanks!
KevinC
'19 Golf R, '21 M2c
P.S. I use a Mac.
I considered doing something similar. I exported a single album in FLAC format and did an A/B test vs 256k AAC, in the car, and couldn't hear a difference, even sitting in a quiet garage, so I decided to hang with AAC. The Fender system is quite decent but certainly no audiophile setup, and especially once you're in a moving car, any discernible difference just isn't there, at least to my aging ears. It's pretty awesome that FLAC is even supported by MIB2. Kudos to VW for making the system so feature-rich. We have a new Mazda3 about to arrive for my gf, and I was reading the manual and it doesn't even have the ability to pick up where it left off if you shut the car off while playing from an SD card. WTH is that in 2017??
I really wish Apple would do some sort of lossless iTunes offering. Kinda baffling that it hasn't happened by now.
Bay Area Smoke Hell
If you're ripping discs or converting FLAC files from sources might have, such as live music recordings, they do... https://en.wikipedia.org/wiki/Apple_Lossless
Otherwise, I'd say if they haven't done it yet, don't hold your breath.
Bay Area Smoke Hell
Yeah I'm quite familiar with XLD, I use it exclusively for conversions, which is the bulk of what I'm handling these days. I'm not ripping CDs though :)
I wish the damn MIB2 would support ALAC M4A files because thats what I use in iTunes, so I'm basically having to handle FLAC for the car and ALAC for home. And stuff I already had in ALAC, that I convert to FLAC, doesn't retain album art and I have to go get it manually, often times resize it, and then place it in the folder on the SD card manually.
It's just such a pain in the ass.
And, you're welcome.
Just wanted to drop in and say thank you for putting this together. Helped me out with getting everything set up (although not all album art works for some reason).
Another advantage that I noticed about the SD over hooking up the ipod is that now I can use the voice commands to navigate the music ("select album..." "select song..." "select artist..."). Its pretty fancy.
KevinC
'19 Golf R, '21 M2c
Try one of the many freeware tools out there for fetching album art and re-fetch for those that don't work - probably just an issue with the size/resolution being too high on the ones that aren't displaying. Or you can just Google the artwork and paste in manually.
I wasn't aware of the voice thing until another post recently mentioned it - that too is a killer feature addition gained by using SD/USB. And the Coverflow feature is really useful, I use it all the time.
deathmonkey
Chicagoland, IL
It looks like it's pretty easy to work with the program and get everything saved on the SD card, which is what I'd like to do as well so there's not an iPod constantly plugged in. However, I don't have a Mac, only PC. Is there any program like this for PC?
KevinC
'19 Golf R, '21 M2c
I would imagine there must be a similar iTunes export utility out there somewhere for Windows. Or you could just do it manually following my guidelines, shouldn't be too difficult.
deathmonkey
Chicagoland, IL
I haven't seen a PC program from my research so far, but I've seen the Export for Mac pop up in some forums here and there, so that's why I ask.
I don't necessarily have a problem doing everything manually, but the big issue for me is the size of my library (approx. 240 GB) and the fact that I don't have iTunes automatically convert files to AAC when it imports them. Do you think having some in AAC and some in MP3 would make a difference?
XeyeL
L.A.
There shouldn't be an issue if some of your songs are AAC and some MP3. I've done it manually, but haven't been able to get playlists to work yet.
KevinC
'19 Golf R, '21 M2c
+1
No reason this should matter.
As for playlists - simply moving the files over to SD card isn't going to work, because the playlists are going to be pointing to the paths on your computer hard drive, not the directory structure/file location on the SD card. Export for iTunes fixes this when exporting your playlists so no problem when using that tool. But moving them manually will require either fixing them manually, or some other Windows tool that can do it.
