Gotcha, sorry. Front wires are cut completely and have a butt connector on each so the wires don't contact anything. I spliced my amped output back to behind the mib to feed the front doors. So the mib is no longer reaching the front speakers or any device. It was sending front output to my dsp before the pioneer went in. I went back to the mib setup because i lost too many features with the pioneer. Now i have a hi res portable player outputting via optical cable to the dsp. Rear speakers aren't seeing amplified power. I just want the mib back for car features, no audio needed.
I was trying to reboot it because the backup cam doesn't show on the screen anymore. I can hear it open. The speedo cluster stuff works and shows speed, miles to empty, etc. Also the gauges in the mib don't show any numbers, tpms doesn't work, no check engine lights though. If i try to set up bluetooth, says i can't do it with the ignition off. Same with setting the clock. But this happens with the car running. Also the mib stays on when i turn the car off, even after opening and closing the door. Only turns off when i lock it with the fob.
Maybe something is pinched behind the glove box unit.
Oh and thank you guys for reading and trying to help.
