Hello, can you pls give me the setup of the tune and the part number for the down pipe. I have seen a couple of down pipes from militek online but I am not sure which one will work for me. Thank and who installed it for you. I am planning to go with militek and stage 2 haven’t figured out the tune company yet. So your input will be welcomed. Thank you.Milltek HJS catted downpipe and a number of others with HJS cats will work for stage 2 and above, plus a tuner that either doesn’t disable the O2 sensor or can flash you back to stage 1. I run the Milltek setup and passed zero issues.
Contact Country Dubs in White Marsh. They can give you all the details you need including software options and down pipe solutions that will work.Hello, can you pls give me the setup of the tune and the part number for the down pipe. I have seen a couple of down pipes from militek online but I am not sure which one will work for me. Thank and who installed it for you. I am planning to go with militek and stage 2 haven’t figured out the tune company yet. So your input will be welcomed. Thank you.
I'm willing to guess the ones that are "EC approved"Hello, can you pls give me the setup of the tune and the part number for the down pipe. I have seen a couple of down pipes from militek online but I am not sure which one will work for me. Thank and who installed it for you. I am planning to go with militek and stage 2 haven’t figured out the tune company yet. So your input will be welcomed. Thank you.
Thank you I will contact them.Contact Country Dubs in White Marsh. They can give you all the details you need including software options and down pipe solutions that will work.
Hey I know this is an old post, but I currently am running a ie dp. Tuned to stage 1 it fails for lean stock pipe in no faults . So what I want to know is what state are you in , and do I need to run a spacer with the hjs milltek cat ?Milltek HJS catted downpipe and a number of others with HJS cats will work for stage 2 and above, plus a tuner that either doesn’t disable the O2 sensor or can flash you back to stage 1. I run the Milltek setup and passed zero issues.
