May have found the replacement for starting vibration reduction on the MK7.5
Reggie Enchilada
nowhere
yes
Ok, I figured that since you have a 19, those options wouldn't be available. Honestly, I'm not sure what else to tell you. Are you getting the flashing ESC light in the instrument cluster when the system intervenes?
Diego Scariot
Brazil
A7xogg
Milford pa
So I messed up, I did the rough road adjustment and now got these errors and all my abs and brakes lights are flashing while ignition is on and driving like I pulled the abs fuse. I can't really look at anything cause I'm at work
A7xogg
Milford pa
I do have a Cobb with a protune so that may explain why im getting this. And I probably shouldn't have tried this with a Cobb, ugh
GTIfan99
I have a Cobb too. I did all adjustments before loading map.
A7xogg
Milford pa
Looking online it seems the car needs to do a steering wheel angle alignment which the car does by itself after 20 miles of driving if u don't have vagcom(I didn't look to see if I can do it obdeleven)
A7xogg
Milford pa
So apparently when I tried to disable the rough road adjustment I think it deleted my long coding for my brake controller. Anyone have access to get their brake long coding for a 2017 Mt gti sport? I don't think it should be all zeros
CloudLv
China
use your own disk..
SW:5Q0-614-517-AQ HW:5Q0-614-517-AF --- ABS Brakes
;Component:ESC H62 0400, Coding:01FA6BA15426096C407F020740C46880D62A900240021636144350D3C0A9430000000012121212B835351919323200
;EV_Brake1UDSContiMK100ESP,036010,EV_Brake1UDSContiMK100ESP_036_VW37.rod
;Tuesday,23,May,2017,20:43:13:29015
;VCDS Version: Beta 17.5.0 Data version: 20170505 DS270.4
;VCID: 804383561B72D447DF-80D4
