Reggie Enchilada
- nowhere
- yes
It can be held even when in Sport to turn off
Sounds like you've got something coded incorrectly. Did you do the coding yourself or have someone else do it?
Interesting, just tested mine and when Sport is activated, holding the button immediately makes the display say "ESC on" then the ESC icon in the instrument cluster turns off once you release the button. Must either be a different option in coding, and/or a difference in model year. But regardless, it works for me, just with different steps.It can be held even when in Sport to turn off
OP, not sure what the issue is, but hope you figure it out. Maybe try the V1 option? Otherwise I'm sure someone else will chime in with long coding instructions or something.
I used the OBD11 app function so I did not do any long coding, just used credits. But yes, when I hold the button I get no beep and the button becomes completely unresponsive, very weird. I suppose next I should go back to the stock setting and try again. Can someone confirm that ESC Sport/ESC Off V2 works properly for your Mk7.5? Thanks!
Thanks for the replies guys, I think that confirms something is funny with mine. Appreciate it!
Set it back to stock with OBD11 and try again. Do you have a COBB AP by any chance?
Yep, I will give that a try and thanks for the help! No AP, only thing on the car not stock is a BMS pedal tuner.
I have VCDS. I disabled rough road, and coded ECS Sport/ECS OFF, byte 29 89 changing to 86. When I hold the button for ECS OFF, it actually says ECS OFF in amber near where my mileage is at. I have the ECS Dogbone Mount. I can feel a much more solid launch, but I am still getting a little power cut. Also, I have ECS OFF, but what about ASR?
