Reggie Enchilada
- nowhere
- yes
You sure that RRO is intervening and it's not a bit of wheel hop that you're getting?
These cars are intolerably confusing, at times.
esc off already?I have disabled both options and it’s still intervening.
Yes - Electronic Differential Lock = XDS - applies brakes to inner wheel to help prevent spin while turning.
Yeah, I have tried to change the bite 29 for 05,06,89,88,87,86... and all of them keep interveningesc off already?
I did not try the eletronic differential lock on weak, I put it in not available, as people do.Correct me if I'm wrong, but isn't the Electronic Differential Lock the name for XDS in VAG-COM given that it's in the ABS module? If so, I'm not sure why you'd want to disable that. Turning it to weak, sure, but disabling it wouldn't really help anything. XDS has nothing to do with SVR or RRO.
Turn XDS to weak, enable ESC Off, disable SVR/RRO, and change the VAQ setting to increased traction. Make sure to turn ESC off when you get in the car and test things out after those tweaks. That should clear up your problem.
Correct! It's not cutting power, it's just applying the brakes to the front (XDS) or front and rear (XDS+) to help with hard cornering.I'm ignorant about a lot of things. XDS doesn't really affect cutting power off the line as per RRO, correct? In my limited understanding, are XDS settings more of a "poor man's LSD" on cars without LSD from the factory? Off topic I know, but curious.
Are you pressing and holding the button in the car to turn it off while driving after making the tweak?Yeah, I have tried to change the bite 29 for 05,06,89,88,87,86... and all of them keep intervening
People don't do that, you're misunderstanding what it's used for. Don't disable the XDS, it helps the car to corner better by braking an inside wheel or two to increase the rotational speed.I did not try the eletronic differential lock on weak, I put it in not available, as people do.
