Odd that a ton of Eurodyne cars are now having this issue.....
I am also throwing a license light plate warning as well. Happened after an update a couple of months back. Maybe we should report it to Tapp hahahahahahahahahahaha
How do I get my current tune to open in maestro?Find offending code(s)
Go into codes list in maestro
set code(s) to 0 in both tables (vag1 and vag2)
save
flash file
Who tuned it?How do I get my current tune to open in maestro?
Pull up the flash tool and download the maestro stage 2 91oct file. You'll need your cable plugged in to do so.It was the standard stage 2 91oct that eurodyne provides
Did you actually flash a Maestro base file in to the ECU? If yes, all you need to do is open the .MSTRO file in Maestro, edit, save. Then you use the Eurodyne flash tool to flash the .MSTRO file in to the ECU.So I upload the tune. It saved a cd file. But when I try to open it with maestro, it says unsupported file type.
Got it. Thanks!Did you actually flash a Maestro base file in to the ECU? If yes, all you need to do is open the .MSTRO file in Maestro, edit, save. Then you use the Eurodyne flash tool to flash the .MSTRO file in to the ECU.
