I think I figured out why the brakes are so weird feeling. Even after I got them to firm up, they never really felt like I'm used to in my old STI or 911. I bought OBD11 to make some changes for track and had an ah ha moment.
The last change to make was for hydraulic brake assist, but I couldn't get it to work in OBD11 because I didn't have the correct security code. Took a couple of days to find it, but in the meantime, I drove around with the other changes and brakes felt the same. I finally found the code and deactivated Hydraulic brake assistance in the 03 module and they brakes actually work like a normal car now. Holy cow, night and day difference.
Here are some of the changes, but hydraulic brake assist is the only one your notice in everyday driving.
03 braking module security code 25757 worked for straight ahead brake stabilization. Turned it off and it'll allow trail braking into a corner without the abs fighting you.
03 braking module security code11966 worked for hydraulic brake assist. Removes the computer controlled brake boost that smooths out your braking and boosts braking pressure in panic stops. Gives you 100% control of brake pressure. Pedal felt amazing after turning off.
32 locking electronic module security code 20103 worked for Expanded differential locking. Set to increase traction and it will increase the pressure to the VAQ and lock the diff quicker and with more force. It might increase pump noise, but that's about it.
These will work on any PP whether you have Brembos or the stock PP brakes.
Enjoy.
