Lol thank you for the pics, jus curious howcome a 345mm rotors will fit the pads better than a 340mm hmmmmm345mm rotors from the MK6 Golf R fit even better than the 340mm. (Please forgive the Craigslist special wheels)
Merry Christmas to us!
Can anyone confirm whether or not they will fit with on R - with 19x8 prets + 10mm spacer ?
The +51 18 x 7.5 do not fit with a 10mm spacer. They're 5mm shy of fitting. The 19"s are 8 inches wide and 1mm more offset, so you should have a good 8mm clearance.
Btw I checked can't code away the brake sensor, have to improvise with connector or u can order from ecs the bypassI bought 340mm rotors for the Macan brake setup but haven’t had the brake kit fitted yet, what is the benefit of picking up the 345mm Mk6R rotors instead (or will it not make much difference)? Shipping back to FCP will probably cost nearly as much as the rotors themselves!
Also, are people that have this setup just coding their brake wear sensors off with VCDS? I have Centric PosiQuiets 10516630 ready to go.
Thanks.
Thanks.
VW MK6 345mm discs by AP Racing & two piece...
https://www.vagbremtechnic.com/ap-r...-front-brake-discs-345x30mm-cp6890-001mnp-g8/
absolute drool fest.....
The benefit is that they're the correct size rotor and have greater thermal capacity. It'll reduce pedal travel too, because they're 2mm wider.
US GTI's don't have wear sensor. R does. There are pads compatible with this setup that have wear sensor. Look at pads choices for RS3
