Long term fuel trim is a stored value that would remain the same as previously stored with the engine off. Short term fuel trim changes should be 0 with the engine off because there are no quick fueling changes being made without the engine running.
I'm guessing it would be good to see logs comparing the same car, same pull before and after to see how both trim values are affected. Idle trim varies a lot and the total fuel map can vary through the rev range. I have no such logs so I am useless here.
Exactly, it was showing the last trim value the moment before the engine shut off, likely idle. You're right also that it takes a great deal of trim before codes light up your Christmas tree. Guys can run 50% ethanol and still not see a trouble code.My car was not running when I pulled the values. I'll check LT a few more times over the next few weeks. I figure there's a min/max range that's acceptable before you get a fault code, which is another reason I don't believe a piggyback can even be suspected. If you're "hot-rodding" a stock car all of the time your LT value has to indicate you've been using more fuel, right?
Great article I found here that sheds light on trims (link below). On a stock tune, in theory you won't see long term trim at over 5% on prescribed pump fuel, and that goes for all the load range. In a [emoji241] piggy scenario, I'm not sure how the trickery works for getting the ECU to add boost, etc. JB4 crowd and their fearless leader probably know precisely. Guys?
https://www.matthewsvolvosite.com/forums/viewtopic.php?t=21123
I'm pretty sure if you drive for 30 minutes after removing your piggyback your fuel trims will be back to before it was installed. No?
Thanks for chiming in on this, George! I assume you meant "doesn't take very long." Feel free to correct me.The LTFT take very long to change. I reckon up to 5-6% higher than 0 there wont be any issue. If its higher they will most likely check for a weakness in the fuel system and start changing parts.
Ah, that's something to think about. Using E20 and APR STG1 LO on my GTI, I see 5% LTFT and 0% STFT at idle and mostly 7-9% LTFT and 0% STFT at partial load/rpm areas of the map.I meant takes long. LTFT is average over whole driving cycle. So it takes quite a bit to make it change considering the amount of time over a driving cycle you full throttle.
