theblackgt
- USA
- VW MK7 GTI / BMW F07
got a weird issue that hopefully someone can chime in on.
when I use the car after a while (at least a day of sitting), my high beams will only work for the first few minutes, and after it stops. however, if I leave just my DRLs on and low beams off, the high beams will work but only flash at the low beam level height. this leads me to think the high beams are working but some sensor is telling it to shoot at the same height as the low beams. this behavior is pretty random too –– sometimes the high beams will work at random after driving for a while, only to again shoot at low beam height a few seconds after. Just today when I was driving home, in front of my garage I flashed and they were working, then after waiting a minute in the same spot, they wouldn't flash at the same height. my car has the OEM lighting package headlights btw, not halogens. I do have custom DRL strips within, but like I said no codes from them and the actual xenon projectors were untouched.
I have no headlight codes either, ive checked my OBDeleven. has anyone had a similar issue or maybe there's a way to adjust the high beam level height without changing the low beam? I already know how to reset the headlight level both through OBDeleven and manually on the light itself, i've done both before.
I'll try to upload a video here later. TIA
