mrmatto
- Jacksonville, FL
- 2024 GTI DSG
Will strongly consider that. Depends on what it costs to have a shop do it. You’ve done it before right?Shop? Dude, we can do the dampeners.
Man dampers and suspension work is easy as anything else, you can 100% do it yourself. Save the money and use it to get a good alignment after you finish the job.Will strongly consider that. Depends on what it costs to have a shop do it. You’ve done it before right?
3 times on my car.Will strongly consider that. Depends on what it costs to have a shop do it. You’ve done it before right?
Im actually the opposite. More than half the time I have taken my car to a shop for work something else gets messed up. I had a buddy work at an auto shop and the stories he told me that the customers will never hear... When I do my own work I know I did it right. Sure it may take longer, but I learn something new and I have the assurance that every single step was done correctly as I did it myself following the service manual or whatever instructions are provided (the forums are very useful in that regard). I get the idea of having a shop be accountable for any issues, but lets say they make a mistake and your car is clunking after the damper change. You gotta take the time out of your day to go back to the shop, talk to them and hope they find the source of the clunk, get the car in and fix it, meanwhile you really have no clue how any of it works. Now lets say you do it yourself and get a clunk. Since you did all the install yourself you have a good idea of what goes where and what might me making the sound. Lift the car up, find it, fix it, boom.Yeah I’ve always assumed it was a PITA. I see stuff about 2x4’s and I’m like unmmm what. I also like the comfort of having a good shop do it because I can take it back to them if there’s a problem. We’ll see!
When we do your suspension, you're going to buy new strut bushings/bearings (Do the assembled Eurosport strut bushing) and offset LCA front bushing and RS3 rear LCA bushing.I get that. Just depends on the job. I did the FMIC install myself and regular maintenance stuff. If I have a clunk after suspension install, I have no idea what the issue is. Hence this thread LOL. And if during install there's a bad bushing that needs replacing? I don't what that looks like, some parts require special tools, and a shop can get a part much faster than I can.
I'm not saying you're wrong. I'm just saying this job is not one I have a high comfort level with yet.
They offer it already installed in a new strut bushing. Get that one. It's a bit of a pain to drill out the center.Lol what. See I don’t even know what those are or what they do. I’m already planning on the Eurosport camber mounts but no clue the others were required. Going to start another thread.
They're usually good for about 30k miles. If you're going to change it anyway, get the one with the Eoroport camber kit already installed to make your life easier.Is the bushing recommendation because the stock ones are typically shot, or for another reason?
Oh sorry I mean the LCA bushings swap. Will def get the strut mounts. Wasn’t sure of the LCA recommendation was handling-based, wear-based, or both.They're usually good for about 30k miles. If you're going to change it anyway, get the one with the Eoroport camber kit already installed to make your life easier.
The offset LCA bushing gives more negative camber and the RS3 rear is firmer than the crap stock one.Oh sorry I mean the LCA bushings swap. Will def get the strut mounts. Wasn’t sure of the LCA recommendation was handling-based, wear-based, or both.
