Mother
- Orlando, FL
Holy shit. Need some bigger pictures.
The BCS Powervalve system uses unique boost actuated variable tone technology, giving a real Jeckyl and Hyde nature - sensible when pottering around and simply Epic on boost, and all with zero drone.
cheers
Nige
I think I'll be going with the Miltek down pipe and probably the resonated cat back. Local shop let me know the exchange rate is in our favor at the moment so it seems like a good time to go that route
Thanks for all the input guys!
Thought I'd update this a bit...
I now have the Miltek catted downpipe on my car. Like the added noise when in race mode. Now after running this setup for the past few months I can say I do want a bit more noise when in race mode. However I'd also like to keep it close to stock when in normal mode since I do drive quite a bit (Bought the R in January with 17k miles, it now has 33k miles).
I think I've narrowed it down a bit to some of the quieter options out there...
-Miltek
-BCS
-Bull-X looks like they did something similar to BCS
There's a pretty good selection of exhausts here:
https://forums.vwvortex.com/showthr...f-exhausts-available-for-MK7(VII)-2015-Golf-R
Thanks Nige!!Happy to do you a forum member discount ;-)
Cheers
Nige
BCS Powervalve
https://www.powervalve.co.uk/index.php?route=product/category&path=308_398_408_421_496
With a downpipe it'll get MUCH louder with a res delete...I have the resonator delete also and installed the AWE switch path remote too. I really like it, pretty quiet when closed but you can tell there is a difference. I went this route too because I’ve read the car can be very loud if you add a downpipe with an aftermarket catback, which eventually I will be adding a downpipe. Also, this route is way cheaper than most of the catback systems out there.
https://www.golfmk7.com/forums/showthread.php?t=29265
I don't like the way that sounds at all. Since I spend most of my commute in the 2400-3100RPM range.
But I want to have my cake and eat it tooThe resonator delete with the valves closed to me is almost not even noticeable.
I don’t get why people want to modify their exhaust then complain about how it sounds, kind of defeats the purpose. If you’re worried about drone or more sound from your exhaust, save some money and leave it stock!
