Blueballs,
I have an EQT turbo and am having similar issues. I'm being tuned by ED@EQT, yet haven't been able to run my newest revision due to the EPC. Mine is kicking on right when I get to 3,000rpms. I thought maybe my IS38 actuator was going bad because the code is for "Turbocharger module A control". I got it to work briefly set to 3.8, but it didn't last long until I got another EPC. I know exactly the lag you're speaking of. For me, when I went WOT, it was like my car was asking, "you sure you want to go? Absolutely sure? Give you another sec to think about it, answer still yes? Ok, I guess I'll go now...). So because of that, I bought a MAMBA actuator and actually installed it today. Like the IS38 actuator, the new one was set to 3.5 and adaption passed. Did a little prayer and did a test drive. Got passed 3,000rpms and thought "yes, it worked!" only to look down and see that it lit up again. I've adjusted the wastegate so many times on both actuators that I've lost count. Looked at everything I possibly could look at and everything seems legit. No leaks of any sort, nothing touching the actuator, adaption passes from 3.2-3.8 and have adjusted the initial wastegate flapper from just barely touching to holy shit that's tight. Nothing is working for me.
Sounds like you’re experiencing exactly the same thing I am. I have the Mamba actuator installed as well. How does the car react at 3.8v’s vs. 3.5v’s? Have you checked your DV? Turbo inlet pipe? I ordered both and hopefully no it fixes it.
I came across this guy who seemed to have very similar issues and he replaced his DV and it fixed it:
