Ultimately I didn’t install one on my VW. After looking at the geometry of the system, the need to remove cladding from the bottom, and the low ground clearance I determined that car was less of a risk than my other vehicles. In the end I bought a product called the “cat strap”. Basically a large bundle of stainless braided cables that is wrapped in an orange vinyl like sleeve that you clamp around your exhaust system. It’s not designed to make it impossible to cut out your cat but to make it a giant PITA. According to the website, the cables can be cut with a saw or grinder but they bind up the blade/cutting wheel which takes time (and makes a lot of noise). Again, make it more of a hassle than it is worth. I have installed two on my trucks so far and the process is rather simple. The kit comes with the cable bundle and several metal zip tie like bands. They recommend adding exhaust clamps but those are not included as everyone has different sized pipes and it would be a pain to include all sizes of clamps. The clamps I bought were easily located at my nearby auto part store. I bought 3 normal sized kits (about 6’ long) and one large size for my Dodge diesel. In the end that jumbo sized one was really unnecessary and the standard one would have worked fine. I’m not worried about protecting the ENTIRE length of my exhaust. If they want to steal the tip of the pipe so be it. The clamps and bands are solid. At first look the bands look weak but they hold solid and are really tough to cut with tin snips. They bind up the blades though a grinder would go right through them. With the exhaust clamps, again, you can cut them with a grinder or saw but it takes time. I have seen other installs online and most use multiple clamps. Safety in numbers. I used four on each vehicle but you can add as many as you like. I cinched them down as tight as I dared without breaking the bolts. Another level of safety might be to weld the nuts solid or add another locknut as a jam nut but place it upside down so that a socket can’t be used to remove it. A pair of open end wrenches would be needed for install or removal…. Again make it a pain for the thief and hopefully they will leave it alone. The sleeve that encases the cable is colored orange (visible warning?) and reminds me of the sheathing aircraft manufacturers put on high temp pneumatic lines. The stuff melts to the cat and is advertised as another way of making it hard to remove. I will post some pics soon. I think the solid cages are more protective but this is definitely easier to install and is more affordable. Time will tell if it works as advertised.
