Thanks but I went with unitronic tune. They are still working on that feature. I'm looking for just a live data with Auto data logger feature. Like an obd2 scanner with those functions.Cobb Accessport.
Do you have one in particular you use? Just to make sure it auto logs if I want at a certain rpm? Thanks.The Torque app and an OBDII plug in which you can get on Amazon for $20.
The only missing is ignition and the capabilities to auto log at a certain time level like jb4 does.torque and OBD dongle will only have very limited number of things you can log. Mostly generic stuff like rpm, speed, boost (up to 22psi), afr, coolant temp, iat, etc. Not knock or any other more specific ones.
What are you trying to accomplish with the logging?
Obd2 brand on AmazonA particular one what?
I will be using this for measuring engine parameters and want it to auto log all the time at a whatever rpm or just automatically if I set it that waywhy are you so concerned about auto logging based on engine rpm? that will really limit your choices and is kind of pointless. You can easily manually start/stop a log and just view the section you want.
If you go bluetooth obd dongle, torque is your best bet for an app probably. A cheap $20 device will work but will be slower than the 'name brand' devices such as OBDLink MX. But again it's limited to generic SAE OBD parameters.
Which is why I was asking what you were intending to use it for exactly? Measure performance times? Monitor engine parameters to make sure everything is running well/safe? etc
Okay thanks
Oh Lord my bad. SorryYou do realize that you just quoted and thanked yourself right?
