most other 17 inch wheels on that site say "25" under weight so I think its pounds. Idk if cheap 17 inch wheels would weigh 22kg (55 pounds)That's probably kilograms lol
The factory 18 inch (Milton) wheels are 10.9 kilograms. That’s 18 inch, which is larger than 17.The factory wheels on most GTI's weigh about 13 kg, if not more, so not unlikely.
Good question! I had weighed them with the tire mounted. I found the weight of the tire online at 22 pounds. The total weight was 49.x pounds. So I believe the wheel to be 22.x pounds. I accidentally found d this out when shipping my wheel-tires which was absurdly expensive. $320+ dollars for shipping 100 pounds of stuff. Total weight was 108 pounds when adding the lug bolts and boxes.Have you weighed them?
that would have the wheel at 27 pounds with a fresh tire. Closer to the 13 kg in question. Here you go. https://www.golfmk7.com/forums/index.php?threads/2018-gti-weight-of-wheels.350675/ 26.3 on a scale. 12kgGood question! I had weighed them with the tire mounted. I found the weight of the tire online at 22 pounds. The total weight was 49.x pounds. So I believe the wheel to be 22.x pounds. I accidentally found d this out when shipping my wheel-tires which was absurdly expensive. $320+ dollars for shipping 100 pounds of stuff. Total weight was 108 pounds when adding the lug bolts and boxes.
I believe this would put me closer to being a math idiot. Not sure where my brain was.that would have the wheel at 27 pounds with a fresh tire. Closer to the 13 kg in question. Here you go. https://www.golfmk7.com/forums/index.php?threads/2018-gti-weight-of-wheels.350675/ 26.3 on a scale. 12kg
Even forged they won’t be 13lbs, some of the lightest and expensive wheels usually can’t even pull that off in 17”.I can't say if it is or isn't 13 lbs, but unless it's forged, I highly doubt it. I've been wrong before, so take it for what it's worth.
The whole back and forth of it even being a possibility with this cheap ass cast wheels is comical. It’s people trying to fight the “too good to be true” mentality. “Nah guys in this case it’s not a typo, on and also guys I just got a crazy deal on a mk8 golf R for 15k and all I had to do was cash app the guy 5k to hold it for me, I trust him” Lol
Now go remove some more 2x4's from your garage. I used to own a construction company so I can tell you which ones to remove first if you like.My thoughts exactly, but I was trying to use tact for once.
I tried.
You aren't getting a 13 lbs $150 cast aluminum wheel in any 18 x 7.5 and if you believe they're 13 lbs, I have ocean front property to sell you in Nebraska.
I feel so much better...
I like Nebraska and I like the beach... how much?
