LIGHTWEIGHT Wheels
odessa.filez
Tampa, FL metro
anyone see lightweight 15x8? I've found rota slipstream in 5x112 at ~14lbs. Looking for something lighter. Seems like other bolt patterns are low et and would be hard to work with using adapters. Thank you
odessa.filez
Tampa, FL metro
thanks I'll check them out
edit, saw them. as with many others, offset is kinda low at 25. with 20mm adapters, I'd end up at 05 ET.
most others in 4x100 are about the same. Hypergrams are et35 and could work with adapters but they are 15x7.5 and I want really want the stretch of 15x8.
bfury5
CT
Unfortunately, getting 18x9 in a lightweight wheel is very slim pickins. Pretty much just Rse11R, Rennform or Freeform. Didn't like the Freeform bronze and silver. Neuspeed were $390 per. So only 1 option left.
Learning that right now unfortunately as I search for an 18x9 autox setup. I don't hate the look of the Rennforms, but all of the wheels I love are sized 18x8.5
