Hello all,
On my VW GOLF mk7 Variant 2.0 TDI I have successfully changed Humidity sensor for RLFS (81D 955 547) sensor, probably from Audi. My car is from 2016, so some parts of the settings are in long coding and some are in adaptation channels.
- Coming home and Leaving home is working as it should. (OFF during day, ON in dark)
- Wipers are working automatically.
- Rain closing is working.
But I cant get auto lights working.
When the switch is in the AUTO position my low beams are always ON, DRL never turn ON during bright day or even if I point bright LED light on the sensor.
On my friends mk7 this simulated sun correctly and his low beams switched off and DRL switched on.
Every physical position of the switch is working (FOg lights, low beam, DRL..)
I have changed everything in long coding and adaptation as was written in this thread. I checked all the parameters from DV52 sheets and compared with mine, everything is looking OK. Can anybody tell me what I am missing here?
I am trying to get it work for a week, I have checked Briskoda forums, Seat forums, Rosstech forums and I didnt find what can be wrong.
Scan and map of 09 module are below.
Thanks.
Code:
Tuesday,23,November,2021,17:53:25:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.12.0.0
Data version: 20201124 DS322.0
www.Ross-Tech.com
VIN: WVWZZZAUZHP512745 License Plate: KKKK
Mileage: 195319km-121365mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZHP512745 Mileage: 195319km-121365miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BN HW: 04L 907 309 R
Component: R4 2.0l TDI H23 7607
Revision: B5H23---
Coding: 01190012032405082000
Shop #: WSC 37048 005 1048576
ASAM Dataset: EV_ECM20TDI01104L906026BN 004004
ROD: EV_ECM20TDI01104L906026BN_004_VW37.rod
VCID: 77FD5EDBCECD4D3C32-8022
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CC HW: 5Q0 614 517 AG
Component: ESC H62 0637
Revision: 00000000 Serial number: 61736000001298
Coding: 04FA62A12421096E477E060441C82920462490E26082947300600078C00203
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_Brake1UDSContiMK100IPB 035019
ROD: EV_Brake1UDSContiMK100IPB_035.rod
VCID: 74E769D7DFBB262417-8020
1 Fault Found:
8400 - Databus
U1123 00 [008] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 244
Mileage: 194911 km
Date: 2021.11.04
Time: 15:31:33
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 BL HW: 5G0 907 044 BL
Component: Climatronic H04 1601
Revision: 00001K08
Coding: 02020104202110011005004000101022
Shop #: WSC 00028 028 00068
ASAM Dataset: EV_ACClimaBHBVW37X 006142
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 72EB6FCFA5AF281405-8026
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
1 Fault Found:
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 4
Mileage: 195073 km
Date: 2021.11.13
Time: 11:54:37
Voltage terminal 30: 14.0 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Auxiliary heater: in stages-Act.val.: 0
Auxiliary heater: in stages-Target value: 3
Auxiliary heater: in stages-Specified value for control: 3
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Component: BCM PQ37BOSCH 028 0163
Revision: -------- Serial number: 8658140616015I
Coding: 00000846C24102FB4FE44000001C07081000000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 03053A0B8A15119C1E-8056
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160528 043 0551
Serial number: 160606035445
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81D 955 547 HW: 81D 955 547
Component: G397_RLFS H06 0002
Serial number: 30056256X81D95554700
Coding: 06A8DD
Humidity sensor: interior:
1 Fault Found:
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 218
Mileage: 195254 km
Date: 2021.11.19
Time: 11:40:18
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331617001523
Coding: 0031051001
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 4385FA0BCA95D19C5E-8016
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR1V75F3
Coding: 98CCC000000000005C0000CF004800000065
Shop #: WSC 00028 028 00061
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 7F0DB6FBE6FD757C7A-802A
Left seat belt tensioner:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H36 0350
Serial number: 34169667D15061651082
Coding: 333135
Right seat belt tensioner:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H36 0350
Serial number: 34169668D14061640641
Coding: 333135
Crash sensor for side airbag: driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 001 806 16
Component: SideSensor_Df 001 0887
Serial number: 357670000008406D4C1X
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 001 806 16
Component: SideSensor_Pf 001 0887
Serial number: 35867000000AB36D4C13
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 5 - Part No SW: ----------- HW: 480 401 806 16
Component: SideSensor_Dr 001 6149
Serial number: 35165029F21160C1B284
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 6 - Part No SW: ----------- HW: 480 401 806 16
Component: SideSensor_Pr 001 6149
Serial number: 3526502AF21160C48073
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 806 16
Component: FrontSensor_D 001 6149
Serial number: 35565029F20EDB64F0F1
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 K HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160129500616
Coding: 0400
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 3A7B87EFBD5F90540D-806E
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 741 B HW: 5G1 920 741 B
Component: KOMBI 203 8311
Coding: 07A511002380000801087A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009051
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 2643439F59E704B459-8072
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AL HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2265
Revision: -------- Serial number: 11061610801911
Coding: 030100041F086800FB00024C080F00010001050000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 7BF542EBF2E5695C56-802E
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 29160001061110016215
Coding: 28FFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 4520510504
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 010 0031
Serial number: 0000205105196
Coding: 003003208000028000001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 4581E413C4A1EFAC70-8010
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000013261692
Coding: 010000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: 0107
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000204974733
Coding: 003001208E00028000801000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 4683E31FF9A7E4B479-8012
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000013249548
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 043 D HW: 3G0 035 043
Component: MU-H-N-EU H51 0687
Serial number: A683F0GS030729
Coding: 02730201FF00000051110001000808001F0100C401200100DF
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_VW37.rod
VCID: 1D316C730CB1C76C08-8048
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL02LAD
Data carrier:
Subsystem 2 - Part No SW: V03 959 809 P HW: -----------
Component: ECE 2021/2022 --- 0192
Serial number: --------------------
Compact disc data bank:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 1013
End-------------------------(Elapsed Time: 03:42)--------------------------
Code:
;SW:5Q0-937-086-AK HW:5Q0-937-086-AK --- Cent. Elect.
;Component:BCM PQ37BOSCH 028 0163 Coding:00000846C24102FB4FE44000001C07081000000000000000000000000000
;EV_BodyContrModul1UDSBosc 15001 EV_BCMBOSCH_015.rod
;Thursday 25 November 2021 19:12:10:00009
;VCDS Version: Release 20.12.0 Data version: 20201124 DS322.0
;VCID: 03053A0B8A15119C1E-8056
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Exterior lighting not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lights not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG133394-Windshield wiper-Frontwischer_Abtauposition not active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 2000 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG133393-Windshield wiper-Tippendes_Frontwaschen not active 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking DELAY 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl not active 4
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl not active 4
IDE02332-Deactivate production mode 0 3
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen not active 8
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen not active 8
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1 0 s 8
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2 0.0 s 8
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung not enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset 0.25 ° 14
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt both sides 14
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel 80 ° 14
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold 50.00 km/h 14
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift ECE R119 14
IDE04923-ENG133379-Turn signal control-Abbruch Komfortblinken active 8
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker SMLS 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion not active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Fog lamp 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus automatic 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 320 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH active 8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft protection-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung not active 4
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm 2 sekunden verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG133387-Access control-Deaktivierung_Laderaumschliessung_extern not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG133386-Access control-Heckfreigabe_Ohne_Verzoegerung not active 8
IDE05142-ENG133388-Access control-LS_Taster_Togglefunktion not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG137162-Access control-Mindestbetaetigung_HDF_Innentaster 0.00 s 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG133389-Access control-Nutzfahrzeug_Schliessung not active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG133390-Access control-Wiederverriegelung_Laderaum Freigabe_Softtouch 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05143-MAS02985-Writing parameter-Value 130 5
IDE05143-MAS04381-Writing parameter-Parameter address FE 00 00 5
IDE05144-Read parameter address FE 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 0 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 0 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 0 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0A 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 1A 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 0C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 0 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 0 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 48 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 4C 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 37 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 41 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 minimize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 minimize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 maximize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 maximize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 0 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 0 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 0 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 0 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 0 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 35 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 35 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 0 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 100 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 100 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 0 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 0 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 100 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 100 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 100 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 100 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 100 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 100 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 100 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 100 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 0 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 35 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 35 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 0 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 0 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 0 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 31 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 31 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 0 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 0 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 0 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 0 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 0 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 29 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 2A 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2E 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 0 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 0 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 0 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 43 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 44 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 1C 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 1D 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 not active 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 not active 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 not active 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 not active 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 12 - Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 12 - Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 not active 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 13 - Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 13 - Bremsleuchten 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 not active 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 not active 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 not active 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 11 - Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 11 - Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 10 - allgemeine Scheinwerfer 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 10 - allgemeine Scheinwerfer 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 Always 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 Always 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 only_if_closed 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 only_if_closed 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 Always 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 30 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 0 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 0 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 0 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 0 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 0 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 8 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 8 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 27 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 0 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 0 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 0 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 13 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 14 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 0 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 0 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 22 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 23 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 0 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 0 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 15 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 15 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 30 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 0 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 0 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 6 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 7 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 30 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 30 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 0 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 0 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 0 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 0 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 0 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 0 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 0 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 0 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 31 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 31 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 9 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 10 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lights-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lights-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lights-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lights-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lights-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lights-Suchbeleuchtung Festwert 100% 8
IDE06425-Dynamometer mode: functional not active 1
IDE06507-MAS13125-Button in center console-Function of button 1 Start-stop 8
IDE06507-MAS13129-Button in center console-Function of button 2 GTE 8
IDE06507-MAS13132-Button in center console-Function of button 3 Driving program 8
IDE06507-MAS13135-Button in center console-Function of button 4 Steering wheel heating 8
IDE06864-ENG115833-Daytime running lamps-Fahrlicht bei Tag Daytime running lamps 4
IDE06864-ENG115832-Daytime running lamps-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lamps-Standlicht aktiviert zusaetzlich Tagfahrlicht active 4
IDE06864-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active 4
IDE06864-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten active 4
IDE06864-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO active 4
IDE06864-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht active 4
IDE06864-ENG115733-Daytime running lamps-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs not active 12
IDE07470-ENG133381-After-run for park light-Bedingungen zur Parklichtbegrenzung abschaltbar über Energiemanagement 12
IDE07470-ENG133380-After-run for park light-Bedingungen zur Standlichtbegrenzung abschaltbar über Energiemanagement 12
IDE07470-ENG133382-After-run for park light-Faktor fuer Verfügbarkeitstimer Faktor fuer x5 Minuten 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 255 min 12
IDE07470-ENG133383-After-run for park light-Standlicht-Verfügbarkeit 24 s 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG128459-Access control 2-easycloselight_aktiv not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen not active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by convenience operation via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen not active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art Permanent 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not_active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG133411-Access control 2-Spiegelanklappen_bei_Wiederverriegelung not active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 500 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent not installed 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung not installed 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI not active 2
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel not installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting not installed 2
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI not active 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit 64 256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach 64 256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum 0 256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel 64 256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher 64 256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko 64 256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd 64 256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer 0 256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI 0 256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2 0 256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3 0 256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4 0 256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI 0 256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2 0 256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3 0 256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4 0 256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab 1 256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf 1 256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI 0 256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay 0 256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit 100% 256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach 100% 256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum 0% 256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel 100% 256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko 100% 256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd 100% 256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren 0% 256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit 100% 256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach 100% 256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum 0% 256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht 100% 256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel 100% 256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher 100% 256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko 100% 256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd 100% 256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren 0% 256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit 100% 256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach 100% 256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum 0% 256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel 100% 256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko 100% 256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd 100% 256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren 0% 256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit 100% 256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach 100% 256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum 0% 256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht 100% 256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel 100% 256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher 100% 256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko 100% 256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd 100% 256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren 0% 256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit 100% 256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach 100% 256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum 0% 256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht 100% 256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel 100% 256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher 100% 256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko 100% 256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd 100% 256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren 0% 256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit 100% 256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach 100% 256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum 0% 256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht 100% 256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel 100% 256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher 100% 256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko 100% 256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd 100% 256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren 0% 256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit 100% 256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach 100% 256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum 0% 256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht 100% 256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel 100% 256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher 100% 256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko 100% 256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd 100% 256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren 0% 256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit 100% 256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach 100% 256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum 0% 256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel 100% 256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko 100% 256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd 100% 256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren 0% 256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit 126% 256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach 126% 256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum 0% 256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht 0% 256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel 126% 256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher 126% 256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko 126% 256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd 126% 256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren 0% 256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit 100% 256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach 100% 256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum 0% 256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel 100% 256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko 100% 256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd 100% 256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren 0% 256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit 100% 256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach 100% 256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum 0% 256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht 100% 256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel 100% 256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher 100% 256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko 100% 256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd 100% 256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren 0% 256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit 100% 256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach 100% 256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum 0% 256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht 100% 256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel 100% 256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher 100% 256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko 100% 256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd 100% 256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren 0% 256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit 100% 256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach 100% 256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum 0% 256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel 100% 256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko 100% 256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd 100% 256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren 0% 256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit 100% 256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach 100% 256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum 0% 256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel 100% 256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko 100% 256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd 100% 256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren 0% 256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit 100% 256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach 100% 256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum 0% 256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht 100% 256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel 100% 256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher 100% 256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko 100% 256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd 100% 256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren 0% 256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte 0 ms 256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit 0 s 256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach 0 s 256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum 0 s 256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht 0 s 256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko 0 s 256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren 0 s 256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit 0 s 256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach 0 s 256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum 0 s 256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht 0 s 256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko 0 s 256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren 0 s 256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit 0 s 256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach 0 s 256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum 0 s 256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht 0 s 256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko 0 s 256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren 0 s 256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit 0 s 256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach 0 s 256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum 0 s 256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht 0 s 256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko 0 s 256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren 0 s 256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit 0 s 256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach 0 s 256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum 0 s 256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht 0 s 256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko 0 s 256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren 0 s 256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit 0 s 256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach 0 s 256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum 0 s 256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht 0 s 256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko 0 s 256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren 0 s 256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit 0 s 256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach 0 s 256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum 0 s 256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht 0 s 256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko 0 s 256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren 0 s 256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen 0 256
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10 E1 30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4 E1 30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5 E1 30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6 E1 30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7 E1 30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8 E1 30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9 E1 30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10 E1 30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4 E1 30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5 E1 30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6 E1 30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7 E1 30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8 E1 30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9 E1 30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10 E1 30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4 E1 30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5 E1 30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6 E1 30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7 E1 30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8 E1 30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9 E1 30
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation Energy management active 1
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement not active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG133391-Convert. top oper.-Remote Lock Unlock Timer s1 0 s 8
MAS05934-ENG133392-Convert. top oper.-Remote Lock Unlock Timer s3 0.000 ms 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein active 8
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze 60 lx 24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze 110 lx 24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle 1000 lx 24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO 30 lx 24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten 60 lx 24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten 110 lx 24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red 80 24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell 100 lx 24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung 4500 mV 24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke 300 lx 24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung 2000 mV 24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke 0 lx 24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung 2 24
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 0 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 0 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 0 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 not active 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 not active 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 not active 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 0 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 0 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 0 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 not active 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 not active 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 not active 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 100 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 Abbiegelicht links 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 Coming Home oder Leaving Home aktiv 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 100 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 Abbiegelicht rechts 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 Coming Home oder Leaving Home aktiv 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 0 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 0 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 not active 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 Always 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 not active 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 0 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 0 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 not active 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 Always 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 not active 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 12 - Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 12 - Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 35 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 13 - Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake lamp 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 35 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 13 - Bremsleuchten 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake lamp 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake lamp 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 maximize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 35 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 29 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0A 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 only_if_closed 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake lamp 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 not active 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 not active 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 maximize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 35 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 2A 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 1A 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 only_if_closed 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake lamp 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 not active 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 not active 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2E 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 0C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 0 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 0 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 0 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 not active 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 Always 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 not active 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 100 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 100 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 0 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 0 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 0 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 0 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 not active 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 not active 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 not active 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 not active 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 0 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 0 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 not active 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 not active 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 0 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 0 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 0 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 0 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 not active 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 not active 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 not active 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 not active 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 minimize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 100 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 0 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 31 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 43 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 48 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lamps 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Blinken links aktiv (beide Phasen) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 not active 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 Standlicht vorn (Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 minimize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 100 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 0 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 31 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 44 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 4C 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lamps 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Blinken rechts aktiv (beide Phasen) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 not active 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 Standlicht vorn (Positionslicht: Begrenzungslicht) 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 Parking light right 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 100 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 11 - Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 not active 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 Coming Home oder Leaving Home aktiv 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 100 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 11 - Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 not active 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 Coming Home oder Leaving Home aktiv 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 100 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 1C 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 37 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 10 - allgemeine Scheinwerfer 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Left high beam 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Lichthupe generell 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 100 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 1D 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 41 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 10 - allgemeine Scheinwerfer 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Right high beam 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Lichthupe generell 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1 active 1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2 active 1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3 active 1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4 active 1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5 active 1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6 active 1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ not active 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar active 16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten 4 16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar active 16
ENG98831-ENG133403-Personalization-PSO_FSG_Setup2_Bit_0 active 16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1 active 16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2 active 16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3 active 16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4 active 16
ENG98831-ENG133408-Personalization-PSO_FSG_Setup2_Bit_5 active 16
ENG98831-ENG133409-Personalization-PSO_FSG_Setup2_Bit_6 active 16
ENG98831-ENG133410-Personalization-PSO_FSG_Setup2_Bit_7 active 16
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt active 8
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung active 8
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
Elapsed Time: 03:08
