It is not working, i try different ways but nothing
could someone send me his full module 9 coding ?
MadMat: I suspect that the answer to your problem is in the settings in your adaptation channels, rather than in the coding-string. I've developed a spread-sheet containing a full suite of adaptation maps for the control module at address Hex09 (i.e. BCM) from a number of mk7s from around the world. The spread-sheet is arranged so that it compares the settings between these various cars . You can download the spread-sheet
HERE.
Unfortunately, all my translations in the spread-sheet are in English (not French) - my apology. However, from the stuff that you have written on this forum, it is clear that your command of the English language is very good, so hopefully you will understand my translations. Please ask if there are any questions
Don
PS: I suggest that you download the spread-sheet and view it on your PC/laptop because Dropbox doesn't appear to be able to manage my formatting
PPS: As a "quid-pro-quo" for access to the spread-sheet, do you have an admap of the BCM from your car that I can include in the document? I don't have a mk7 in the spread-sheet from France!
PPPS: If you still want to check your coding values, you can download a full set of long-coding screens for my BCM
HERE (my car has CH/LH operating successfully).
