My statement is the same with an auto or manual...
In general, peak weight transfer during braking occurs up to the turn in point. From there you trail brake and continue to reduce brake input up to the apex (and more often than not the 2ft or so before the apex). This keeps reducing the weight over the front gradually as the front slowly lifts. At some point before (or at) the apex, you're adding throttle, and the more lag your engine has, the sooner you have to be on throttle.
I don't see where you're "transferring weight while still on power". There's the idea of maintaining nose down on turn in with trail braking, but you don't need lfb there. There's the idea of adding power while on brake to build boost or get back into power sooner, and that's super valid. Using brake after you've started adding power on exit I don't really see, as even mild reduction in throttle after wot can pitch the rear and transfer a lot of momentum forward.
Don't get me wrong, lfb is a valid technique and can certainly be helpful, but it's not a critical skill set to being faster in most amateur cases. My advanced de students in manuals i encourage to try lfb in certain corners and based on their car and balance. My intermediate de students in autos I encourage to start lfb if they're in boosted cars or they have a hard time with being smooth coming off the brake. We're looking for perfect sharkfin curves on the speedchart, no sudden added deceleration or shakiness to the line at the bottom of the curve.
I just don't think it's a worthwhile skill to focus on until you've already figured out the perfect line, turn in, track out, brake application, brake de-application, and general smoothness in weight transfer.
Read from Ross, he rocks!
https://speedsecrets.com/the-pros-cons-of-left-foot-braking/
