Okay, so I got it done as DIY - Had to do it twice though.
I did remove the intake manifold to get access to thermostat and pump and left the throttle body on the intake manifold.
I also removed the FAN assembly to get a bit more room to work with. That is a 5 task BTW.
The first time I ended up with a huge leak, most likely because the union which goes to the oil cooler was improperly set... I found this, only at the end, at 11:30 at night.
after I put everything together.
Second time taking it apart and putting back on, I did test the cooling circuit by creating a vacuum in the system, before putting intake manifold and all other guts back - just the thermostat and water pump put in place.
I strongly recommend this step which I did not see mentioned somewhere else. BTW - I did use the instructions from the DAP youtube video.
I can say that I can do it again in ~4hrs if I ever have to do it again, but is quite laborious process.
Most of everything is so tight and in the way of something you need access to. Patience and attention are your friend.
Make sure you do not break any electrical connector in the process, as there are a lot you need to touch.
What I would do different next time is to wash with a water hose the engine from all the coolant you will spill in the process of removing hoses/ thermostat. This will allow you to see if coolant leak is fixed or you are observing coolant dripping from the engine block.
I will keep observing mine in the days to come but for now appears there is no leak.
FWIW my OEM thermostat revision was 'H' and the new one purchased from DAP was 'P' Before soon, they will be running out of alphabet letters for Rev # on this part. Whoever designed it wanted a secure job
Good luck!
