anotero
- Hither and thither
- Mk7 GTI
I have 73k miles on the odo. When should I change the LCA bushings?
Sent from my SM-G965U1 using Tapatalk
So these are OEM control arms with full rubber bushings? Also, are the ball joints OEM? I would get this set, but I have no need for new ball joints as mine are doing just fine.We just released a kit and will be making a formal announcement shortly. Ours uses a RS3 solid bushing.
https://blackforestindustries.com/c...ms-rs3-solid-rubber-bushings-with-ball-joints
glad to see y'all released the kit. I was pretty excited to see them in person when i visited the shop 2 weeks ago.
Does the LCA come with just the rear bushings? Also, what's the difference between your all rubber bushings and polyurethane ones?These are not OEM VW. They are manufactured to our spec by a Tier 1-level supplier.
We do sell just the bushings itself here: https://blackforestindustries.com/c...rs3-control-arm-bushings-solid-rubber-mk7-mqb
I love the look of SuperPro LCAs, but don't want to deal with all the caster. I'm lowered and run 235 tires already.
How much caster do they add? They come with all the SuperPro bushings, right?im almost all the way down on pss10s with 245/35/18. zero rubbing on their newest arms
