anotero
- Hither and thither
- Mk7 GTI
I'm looking to replace my PCV and would like to know the latest part number that works well on the mk7 GTI.
It’s OEM though. The VAG logos are scraped off. Seems strange it would be a different revision VAG doesn’t (or doesn’t yet) recognize.-AR looks like an aftermarket revision. I'd avoid personally.
Yes. What I mean is: does the B or A indicate a specific difference? Because the BM looks the same as AP.Yes BL is different than AP.
Are you sure they were VAG logos? Could be Vaico, or another chinese manufacturer. The inconsistency of these PCVs tells me that if you can get OE-level QC, it's probably worth sticking with the genuine parts. Googling that part number all I get are alibaba listings. I'd bet urotuning got a line on a cheap chinese-market part and is just scraping the logo off to obfuscate that.It’s OEM though. The VAG logos are scraped off. Seems strange it would be a different revision VAG doesn’t (or doesn’t yet) recognize.
BL on the left, AP/BM on the right:Side note: Does anyone know why there are b-series (BL, BM) and a-series (AH, AP) PCV valves and if there’s a specific difference between the series?
I certainly hope that’s not the case since Uro labels this as an OEM part. That’s the only reason I bought this one.Are you sure they were VAG logos? Could be Vaico, or another chinese manufacturer. The inconsistency of these PCVs tells me that if you can get OE-level QC, it's probably worth sticking with the genuine parts. Googling that part number all I get are alibaba listings. I'd bet urotuning got a line on a cheap chinese-market part and is just scraping the logo off to obfuscate that.
FWIW, the BL valve worked terribly for me and even let oil into the manifold under regular driving. And VW doesn’t list the BM as compatible with my GTI (it says it’s for the R). It’s all a bit confusing and opaque.BL has that check valve near the rear, whereas AP has that baffle on the front. My guess is that baffle's proximity to the intake manifold return is why the BL seems to do a better job at not dumping oil into the intake on heavy braking. My first BL failed and my assumption is that check valve doesn't hold up well to 31+ psi of manifold pressure.
As for BM/AP/AH, it's possible there's no significant design change, just a different supplier, or another minor revision creating a supercession. Some motors seem to like one over the other.
I mean, I can also find BL, BM, AP as cheap Chinese knockoffs too so it could happen regardless. Disappointing to see from Uro and I have to think it’s an honest mistake and not a purposeful intent to deceive. They’re a well respected company, I thought…You mean people would do that, just go on the internet and resell $20 aliexpress parts at a 400% markup? (yes, yes they would).
Google it yourself, that's not a genuine VW part number. The results are alibaba, amazon, or ebay resellers.
Aren’t almost all online retailers drop-ship companies? They stock certain items in house and the rest is drop shippedIt can, but I'd say it's a lot more likely from these drop-ship tuning companies. Maybe not as likely as amazon/ebay. Not saying it's guaranteed to fail, it's just shady AF .
Urotuning: at least we're not ECS.
