Kufatec footwell lights coding
Anfas
Ukraine
2015 Golf 1.8L
Hey!
I’ve installed foot well lightning in my Golf S 2015 and it works as expected, but I can’t see the % setting under “Lights” menu in my MIB2 system. I have the opportunity to change the intensity only with cluster brightness slider. As far as I understand the setting in adaptation which should add “Footwell lights” menu is “IDE09732-ENG114629-Interior light: light configuration-Foot well lighting”, correct? Can someone suggest what could be the reason?
I’ve done next adaptations for 09 block, long coding wasn’t used:
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting -> installed
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 -> 36 - LED Kleinleistung
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 -> 2
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 -> Footwell light
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 -> 85
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 -> Terminal 58xs dimmer
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 -> Interior light
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 -> Always
Thanks in advance.
Fraysa
Israel
2016 MK7 1.4TSI
Hey!
Thanks in advance.
Hey,
This has already ben discussed over 10 times in this thread. Please look in the previous posts for the correct coding; the one you posted is a workaround.
