The Konis don't have internal bump stops....reuse your OEM ones and trim them (if you wish), although I believe the OEM ones are plenty short already
Yes, reuse the OEM rubber isolator
Thanks! I'll reuse the stocks as is.
Just installed Konis with DG springs and they are a huge improvement running full soft. Will adjust damping after getting a feel for them.
Over OEM. I think the setup is still settling a bit but about .75" to 1" drop. I didn't measure prior. No reverse rake so far. Better traction and flatter turning for sure.Over what, OE? How much lowering did you see with the DGs and Konis?
Just picked up a set from tunersports. With the $50 Koni rebate it takes it down to around $500. Pretty awesome.
Are you swapping out the HPA coilovers?
Ordered a set of Konis from Tunersports. Thanks for the heads up!
Also order Euro spec Eibach linear springs from Amazon.uk.
Won't be able to install until April, going on a trip to Colorado.
