Yes. Definitely making a few assumptions.
My assumptions about their chosen rates could be wrong. If the math says their rates are right, awesome. I'm wrong then. After driving/autoX/HDPE MK5/6 era GTIs, and WRXs with ranging from 300 to 500 + spring rates in various combinations (with mostly AST 4100/5100s series shocks, 2008-2013 vintage, stated to be valved handle up to #650 range). Generally, rebound on the mid to soft settings front and mid to high settings rear. Granted the mk6 had swaybars, GC camber plates, with zero toe in the rear, seemed to be fairly neutral in the 300-350 ish range in the rear with stated farkles. My butt wouldn't call the setups that had 450+ or more rate daily-able long term, dual duty setup. For a mostly Track bias though setup, they might be spot on for a Mk7 GTI. Can't wait till someone gets them in hand and post impressions.
Maybe someone with more info can shed light, if they are making R/S3, RS3 specific spring rate SKUs, but I am assuming they are going to sell the same SKU to all VW/Audi MQB range from std golf to RS3 your going to get the same rate(s) for cost on KONIs side (one size fits most application range.)
AUTOCROSSER FOCUS ONLY (Track guys need stability and predictable understeer so they don't hit stuff)
I think the whole spring rate discussion is actually miss-understood and blown out of importance.
I've run anywhere from 350-750 front and 350-1000 rear springs on my Mk7. The only takeaway from all that testing (and I tested a lot) was that the spring rate needs to matched to the racing surface, and that I like a equal F/R wheel rate (which equates to a "higher" rear spring rate) spring setup so that when the front hits a bump, the rear is ready to react quickly and not take long to recover to neutral.
I don't run this setup for oversteer. It does not work. I don't run high rear bar and high rear springs for oversteer, it becomes unpredictable and sliding is slower.
I focus on added traction through a stiffer front bar for less front camber loss, and as much static camber that I can get.
The real magic is 1/8 inch of rear toe out. I'm spilling the tea here guys, not enough of you all are trying this. This is where the rotation comes from, not a big rear bar. A big rear bar is just less grip everywhere. The handling does not feel like rear sliding, it's just the rear following the front, generally very little understeer and lots of grip.
Big front bar setups are being slept on.
Pick the spring rate you want, and send it. I have a preference, but rear toe out will make a bigger difference than the "perfect" spring combo.
Oh, and for shock settings, compliance is key. I don't run "more rear rebound" to get rotation either. In a class where you can pick coil overs, spring rates, shock settings and alignment, over dampening the rear is entirely unnecessary. My Ohlin's are set to a very comfortable level so that I have maximum contact with the bumpy lot I race on. I don't change the settings between track and street and I daily drive 400/650, big front and rear bar.
