JerseyDrew's 2016 GTI S build, a.k.a. Jersey Devil
JerseyDrew77
Virginia & NC
2016 TR GTI S 6MT
Straight to the damn point, my mod list...
Brakes
Hawk HPS 5.0 Pads (Rear)
VTT Ultimate Drag Brake Kit w/6 POT Wilwood Calipers (Front)
Stoptech Slotted Sport Rotors w/USP SS Brake Lines (Rear)
Wilwood Pads (Front)
Engine
AEM 5 Bar (intake manifold)
APR Oil Catch Can
Bosch 4 Bar (charge pipe)
Braille Green-Lite G30 Battery
DBV2 3.5" Air Intake
DBV2 3.5" Dump Tube
DBV2 Big FMIC
DBV2 G30-900 Turbo Kit
Fluidampr
Galano Engineering Intake Manifold
iABED Throttle Body
NGK Racing Plugs (Heat Range 9)
SuperPro Engine Mount Kit
Exterior
Aerofabb Competition Series Rear Diffuser
Aerofabb Rear Spoiler
Aerofabb Side Splitters
Black GTI Fender Emblems
Debagged Rear
ECS Rear Diffuser
Ed’s Replicas Headlights with Morimoto Elite 5500K HID’s
Ed’s Replicas MK 7.5 Taillights (Dynamic Turns)
EmK Lighting Smoked Dynamic Turn Signals (side mirrors)
Gloss Black Front & Rear Emblems
Gloss Black Mirror Caps
Plastics 4 Performance Lexan Polycarbonate 7 Window Kit
Premium Deutsch Carbon Level 2 Vented Hood
Premium Deutsch Carbon Level 3 Rear Hatch
Rear Wiper Delete
Fluids
Motul Competition Gear Oil 75W140 (transmission fluid)
Motul RBF 660 (brake fluid)
Motul Sport 5w50 (summer oil) and 5w40 (winter oil)
Fueling
Fore F2i Fuel Pressure Regulator
Galano Engineering Flex Fuel
Galano Engineering MPI Fuel Rail
Nuke Performance Full Flow Flex Fuel Sensor Adapter
Precision Raceworks 1300cc MPI Fuel Injectors
Precision Raceworks Stage 4 LPFP
Radium Engineering Fuel Pulse Damper
RedHorse -8AN Fuel Lines
RedHorse Inline Fuel Filter
Torqbyte PM4
Suspension
Fortune Auto Custom 510 Coilovers
H&R 24mm Rear Sway Bar w/SuperPro End Links
SuperPro Adjustable Front End Links
SuperPro LCAs
Verkline Spherical Adjustable Rear Trailing Arm Kit
Tires
Toyo Proxes R888R (235/40/ZR18)
Transmission
Boomba Racing Weighted Shift Knob
Built Transmission by FFE Racing with Dog Gears Set, Steel Shifting Forks with Bronze Sliders, and a Wavetrac Differential
Dieselgeek Sigma 6 Short Shifter
iABED Billet RMS
SPEC Mini Twin Drag Clutch w/Lightweight Steel Flywheel (Single Mass)
Spulen High-Flow Bleeder Block
Torque Solution Shifter Cable Mount Bushings
USP Motorsports SS Clutch Line
Wheels
Apex Stud Kit
Enkei Racing RS05RR 18x8.5 ET45 (Matte Dark Gun-metallic)
Engine was built with the following parts at 81,840 miles:
ARP Head Stud Kit
ARP Moly Fastener Assembly Lube (2 packets)
DM Forged I-Beam Rods
Elring Liquid Gasket (AFD 2018)
Ferrea Super Alloy Intake & Exhaust Valves
Ferrea Valve Spring & Retainer Kit
Forge Silicone Coolant Hose Kit (Red)
IE Performance Valve Guides
MAHLE Calico Coated Race Rod Bearings
MAHLE 82.5mm Pistons (ceramic coated) with 21mm wrist pins
OEM Cam Timing Chain, Rails, and Tensioner
OEM Head Gasket
OEM Main Bearings
OEM Oil Cooler Gasket
OEM Oil Pan Gasket
OEM Thrust Bearings
OEM Timing Cover Gasket
OEM Valve Cover Sealant
OEM (TRW) Valve Keepers 6mm Triple Groove
OEM (Elring) Valve Stem Seals 6mm
In possession but not yet installed:
Belak Industries Series 2 Wheels (Fronts = 15x9 three piece, single beadlock w/ARP beadlock hardware; Rear = 15x3.5 one piece skinnies)
JE Ultras Pistons
Pauter Severe Duty Rods
Racetech RT4119 Series Race Seat
JerseyDrew77
Virginia & NC
2016 TR GTI S 6MT
Here's my very first dyno run back on March 09, 2018. My car was not tuned at the time but had the following mods: CTS direct fit IC, COBB intake, MAP downpipe, and AWE track cbe.
JerseyDrew77
Virginia & NC
2016 TR GTI S 6MT
Bought some new summer wheels this past Thursday. Picked up the Enkei RS05RR wheels in a Matte Dark Gun-Metallic color but they are currently out of stock so it will take 2 - 3 weeks for them to come in. So now my VMR wheels will be my winter wheels and the Enkei's my summer wheels.
Next will be some Belak wheels with slicks for the dragstrip.
Enkei Racing RS05RR wheels
