- Phoenix
- 2018 SE DSG
You're getting a mixture of combustion blowby and water from the cold weather. It should still be a very thin viscosity though.Okay, so I am having a little issue here with my Spulen OCC. The actual catch can is the problem. It fills up with blow-by and when I go to drain it, nothing flows out BECAUSE the blow-by is this thick sludge that, apparently, is too thick for the drain valve. I have to physically remove the can, along with the drain valve from the can, in order to drain it. As you can see in the picture below, the can was full of that thick sludge and that's only from 5 days of driving with a handful of WOT pulls. So now I am searching for just a can that screws open in order to drain it.
Below is the can that I use with the Spulen OCC. It unscrews to empty but it's smaller than the Spulen can which means you'll have to empty it more often. It's a baffled can and works great. Just put your current hoses on this can.
https://www.ebay.com/itm/Universal-...-/264840182611?_trksid=p2349624.m46890.l49292
