Has your username changed as part of the site merger and want it changed back? If the other version of your username isn't being used, send Gulfer a PM and we can probably fix it for you
Yes it is sir. I’ve seen that all JB4s are the same internally, but the preloaded maps have different boost pressures. So theoretically you could use this on other platforms and use map 6 to set your desired boost values.
