That looks better but it's odd because the throttle registered at 100% in the earlier graph and the bit I looked at with low boost. Must be a glitch. If it's a DSG, just put it in manual mode.Hey, I didn't know when I first posted I had to have pedal at 100. Did a few pulls this evening with pedal to the floor. It doesn't look like I'm pulling any timing throughout the rpm range
Here's the new log
https://datazap.me/u/wire55/gti-map2-dp-intake-ic?log=0
Try map 3 to start. I suspect that with your setup, depending on gas, you'll be able to get added boost at higher rpm to where you may need to add a bit of FOL. That said, you may just be happy with Map 3.
