shovelhd
- Western MA
Got some logging done with Map 4. Trying to take advantage of this cold weather and build map 6.
Can someone give some settings for map 6 to try?
Logs https://datazap.me/u/jackphom/jb4-m...-pull?log=0&data=1-8-11-12&solo=11&mark=57-81
https://datazap.me/u/jackphom/map-4-second-log?log=0&data=1-4&solo=4&mark=212
Don't use someone else's settings. There are too many variables. I also wouldn't use Map 4 as your baseline unless you're running E85. Start with Map 1. Your logs have a lot of junk in them, too. Start the log at 3rd gear 2500rpm and run it up to your 4th gear shift then stop the log.
That said, there's some data in the middle of your second log that's pertinent. You're getting a little timing pull but nothing alarming. Map 4 is +6psi with a taper. Set up your initial Map 6 to look just like your Map 4 log. Run the logs again. That's your starting point. I'd also point out that it's cold in NYC now and your Map 6 created during boost season is probably going to be too hot for the summer. If you want to run your car on the edge, you need to keep checking logs as the temperature and fuel changes during the year.
