Map 3 pulls so hard! I can't believe I can run that map with ACN91 octane..
Do I just copy the target values over and start incrementing the numbers? Do you know what values to put for 1500-3000?
You can do a pull in map 3 from 1500 to 3000 and figure those numbers out, or just plug in 1, 1.5, 2 . That should be fine. You can try to +1 all cells from 5000 to 6000 rpm.
The 2019 cars run really rich, so it cools the cylinders more for running more boost. The 2019 GTIs (not sure about R) are very good candidates for piggyback computers.
