I'm aware 2.0s run less timing but it isn't climbing much at higher rpm. Also, trims are 'lower' than you'd expect with e85 so I suspect the fuel pressure has been raised.@goodvibes
Keep in mind the 2.0 ECUs run lower timing than the 1.8s. The higher trims are likely because of the E85, but I wouldn't worry about it.
