Andrewbens
Modesto
2019 GTi S 6 Speed
what setting did I send?
my map6 setting with the is20?
you should try e30 (2-3 gallons of 85 with the rest of the tank full 91)
With map 3 fol 60 and post that log.
map 3 is good for clutch concerns cause George created it to be less aggressive down low than 1 and 2 in efforts to keep the temps low so it can make the higher boost with timing in the higher RPMs. I was alway a fan of how map 3 felt VS 1&2, but it’s def not a snappy at 3-5k
Ohhhhh I’ll try it tonight this was the settings I was running
Andrewbens
Modesto
2019 GTi S 6 Speed
El_bigote_AJ
Las Vegas
2019 GTI bunny
Speaking of hitting a proverbial wall, this has happened a couple times sporadically in the last few days... it was happening everytime I forgot to turn off the acr/esc so I thought that was it but it happened tonight again with those both off, at first I thought it was maybe hitting a governor but I’m not going fast enough at all, and it’s not Throwing a code like it’s going into limp, so maybe someone has some insight as it happened tonight while I was logging. It’s consistent at 6k too, I’m full pedal to the floor and it’s just quits on me like it hit a reve limiter. Then other times it’s will spin to 6500rpms, so I’m confused.
https://datazap.me/u/elbigoteaj/log...18-36&solo=4-14&trim=5&tmin=78.35&tmax=100.00
CHHA
Germany
2018 Octavia RS
Hmm sounds not normal. I am having once in a while the front assist making an emergency brake if he is detecting something only it can "see"
Andrewbens
Modesto
2019 GTi S 6 Speed
Hopefully 91 octane is dialed in 4.5+ from 4,000rpms and all the way to 7,000
50 FOL
put some E30 in the tank gonna do a map 3 run tmrw didn’t haven’t enough time for the e30 to mix in so I’m letting it settle in before some map 3 fun
https://datazap.me/u/andrew149/91-o...14-18&solo=2-3-4-6-10-14-18&zoom=0-20&mark=19
Andrewbens
Modesto
2019 GTi S 6 Speed
El_bigote_AJ
Las Vegas
2019 GTI bunny
hows my latest log looking ?
Too much boost, still no to low advance up top car is getting high egts and dumping fuel to try and cool that’s why it’s at like afr10.1 at 5k.
Also IATs creep good, was was the weather last night like? 50-60f no? Iat was over 100 at the top of the run... you need an IC before it gets warmer for sure.
For me the IC was a much better driver dyno return than the DP, but it could be cause I did IC first then DP
Andrewbens
Modesto
2019 GTi S 6 Speed
figured it wasn’t looking good I was running this log after I got off work so I think it was about 50 degrees last night. I think this car definitely needs a intercooler badly for sure.
El_bigote_AJ
Las Vegas
2019 GTI bunny
Use the same setting with blended fuel and see how it looks
Andrewbens
Modesto
2019 GTi S 6 Speed
I’ll get one out tonight I have 3.2 gallons of E85 in the tank I was ready for map 3 like you were saying that was gonna fun what fop are you running with e85 60fop right?
El_bigote_AJ
Las Vegas
2019 GTI bunny
You have the rest fully topped with 91 right ? If you get too much 85 the fuel pressure can’t raise enough to give the extra volume of fuel needed
I’ve run it with 50/55/60 before. Right now 55 is pretty good for me.
Andrewbens
Modesto
2019 GTi S 6 Speed
Yes sir I used the calculator
Andrewbens
Modesto
2019 GTi S 6 Speed
Having issues with cruise control every time I clear codes I can’t use my cruise control what do I do to get it working again?
