Andrewbens
- Modesto
- 2019 GTi S 6 Speed
what setting did I send?
my map6 setting with the is20?
you should try e30 (2-3 gallons of 85 with the rest of the tank full 91)
With map 3 fol 60 and post that log.
map 3 is good for clutch concerns cause George created it to be less aggressive down low than 1 and 2 in efforts to keep the temps low so it can make the higher boost with timing in the higher RPMs. I was alway a fan of how map 3 felt VS 1&2, but it’s def not a snappy at 3-5k
Ohhhhh I’ll try it tonight this was the settings I was running
