This is the only reason I am keeping my current firmware. The auto clear of the o2 codes works 95% of the time. About once every 2 months a cel will slip through and I'll have to manually clear it, but that's after it has auto cleared almost daily. Wife would go ballistic if the light stayed on all the time. She already thinks I'm destroying the car instead of upgrading like I keep telling her. Lol.
installed the hybrid last night, ran it on map 1, checked logs, then went map3 checked logs and created initial base Map 6 setting as below for test and run.
just talked to George about them today and ill be added some request after 5k and will run some more logs tonight... this is still on e3blend.
whats crazy feeling is how much faster the car feels from the added volume of the bigger turbo will still at the same boost levels of the is20 (except after 5800rpm)
https://store.034motorsport.com/r46...-s3-mkvii-volkswagen-golf-r-2-0-tfsi-mqb.html
got it used from a local member here in Vegas, 034 tunes it very mild....loba (the company they partner with for the turbo) has done 450+ With it on pump.
he ran it for 4k and decided it was not enough so he pulled it and had the motor build and went EQT xl - doing low 500 on 91, and highs on full e85. I rode in it on 91 and holy SHIT it goes !
I did the same for so long I thought it would never update to new firmware. Wanted to experiment and take advantage of some features with new F/W. So bit the nipple and took the plunge. Sure enough, CEL. Installed Vibrant straight spacer with medium insert and no light since. MAp 3 is nice in warm weather. Worth it.
So now that I have a downpipe installed can I turn the boost up a little? Can I turn my fop down from 55 to 50 just wanna know what you guys learned after from from stock and then a downpipe installed and what more you were able to tune in. 91 octane with dp and Jb4
I had similar problems using BT on a Samsung phone. The JB4 app could not find the new downloaded firmware. I used the Samsung My Files app to move the new file out of the Downloads folder to the JB4 folder, where the other firmware revisions live. Once I restarted the app, the new file was visible in the JB4 app, and I was able to flash it.
Seems to add about .5 PSI from 3K on compared to map 2. Its a bit hot for my car in the cooler months as it shows more ign corrections due to torque targeting profile of my ancient ECU. Summertime it works fine. When I feel particularly anal, I go between it, map 2 and 2 different map 6 files depending on ambient temp. As long as you can get clean boost without serious AFR fluctuations and IGN corrections, you're good. Once you start getting lean, or knock (depending on generation of ECU) , you are on a ragged edge and should adjust boost accordingly. Especially in regards to fueling (FOL /trim). Lots of trial and error depending on conditions to get a really fined tuned JB4 car from what I've found.
Diggs got my map 6 dialed in pretty good. I have a conservative one for easy driving/ wife mode and a couple of hot ones depending on if I get corn or not.
With lower back pressure you are alredy moving more air mass at the same boost as before and since you are running 91 log map1. When you have E30 in the tank run the numbers I posted before with FOL 60 and post the log before you turn it up.
