TraceMe
San Diego
2019 Golf R DSG
Really trying to figure out what is going to work best on my car. I have been fluctuating between map 1 and map 2.
I am in Cali with 91 octane (occasionally running 2 gallons of e85) and between map 1 and 2.
My car is a 2018 Golf R manual, stage 3 SB daily clutch, CTS DP, R600 Intake, Turbo Muffler Delete.
I took a couple of logs, please let me know if I should change something up, looking for the most ideal settings.
https://datazap.me/u/traceagain/1st-pull?log=0&data=1-4
https://datazap.me/u/traceagain/2nd-pull?log=0&data=1-4
https://datazap.me/u/traceagain/map-1-pull?log=0&data=1-4
Diggs24
de plains! de plains!
2015 GTI
map2 will not work on 91ACN, map1 often barely and usually doesn't when it gets warm out. If you can stomach the E85 then run it all the time and map2 and further is a non-issue.
Jambroni
Sweden
Seat Leon Cupra ST
Keep an eye out for 3AD2 codes. Looks better but can still see it capping. AFR looks good because you aren't pushing 7+psi.
Thanks, will try the map 6 with FOL 60 a bit more and check codes.
Edit: Should I try to up the boost a bit more or what do you think?
TraceMe
San Diego
2019 Golf R DSG
Im also running an IE intercooler, idk if that changes anything.
Jambroni
Sweden
Seat Leon Cupra ST
What RON gas are you using? Good timing advance going higher into the RPMs but you're seeing timing pull from the moment you go WOT to 6000 rpm.
Ron 98 so it should be the equivalent of US 93 I think.
