Diggs24
- de plains! de plains!
- 2015 GTI
Thats the speed governor in 4th
DV spacer has no effect except for sound.I did take some! Gotta look through them.
@Diggs24 am I dumping boost due to the speed being governed? I thought it had something to do with RPM but looking back at it, it starts around 107-110
edit: or maybe my dv spacer?
Looks OK to me and I wouldn't bother trying map 2.First time logging, can someone take a quick look and let me know if it's ok? Please and thank you. Was only able to get one run logged.
Shell 91(Canadian gas) on Map 1.
I don't know how to properly read this but any issues with ignition 1?
Log
Knock sensors pulling some timing, not an issue but no point in adding more unless you can improve fuel quality.Where on the logs do you look to determine that? I'm still trying to figure out how to decipher them.![]()
datazap.me | Jluu | Log 1633041187
Boost taper is normal in this situation. You need to do a log where you go WOT at like 2800-3000 RPM to at least 6000 rpm.Trying to build out Map 6, no mods other than airbox mod and drop in filter. Is it normal for boost to taper off past 4k rpms?
Any suggestions on what to use for settings on Map 6?Map 2 3rd gear pull
@ZuMBLe thanks for looking it over, I'll do another log and try out Map 4 since it's getting cooler here.
Is it even beneficial for me to go map 6 without more mods?
There is a JB4 thread in the 1.8 forum. In that thread you'll find JB4 values for a completely stock 1.8.So I have a 2019 Golf Alltrack that I recently hooked up a JB4. My car is completely stock and I typically know nothing about tuning cars. I'd love some feedback though as I feel I did 3 logs all in 3rd gear starting at 20mph until the car hit about 6000-6500rpm. Any help is greatly appreciated to know if the car is running good or what needs to be changed or possibly even having a map created.
I have the logs saved as an excel but not sure how to attach here or what I can do to pass that off to show.
Thank you! (From a newb)
Figured out how to get the log if anyone can take a look.
https://datazap.me/u/yamba6/first-logs-pulled?log=0&data=1-4
Yeah, I noticed after I posted that it said this was in the GTI engine section and I noticed your post and saw cars: Alltrack 6MT. It didn't dawn on me till after I posted. Thank you.There is a JB4 thread in the 1.8 forum. In that thread you'll find JB4 values for a completely stock 1.8.
