shovelhd
Western MA
Can you run your log again? Just one full throttle pull from 2500 to redline in 3rd gear.
It's possible for boost to blip up for a very short period between shifts. What you need to look at is the boost across the rev range in one pull with at most one shift.
phoffman183
Chattanooga, TN
16 GTI SE
I will do that at lunch and post it but I'm not seeing 28 psi while shifting, it happens during the pull right before I shift then it goes to map 8.
See below, white is Boost, grey is RPM and purple is Map
Drincc
Vancouver, Canada
2019 GTI
Silly reference question: After putting in JB1 it does say to WOT a few times for relearn. Where did y'all find the space to send it for that? Everywhere I go is traffic.
goodvibes
IL
I just floor it in neutral.
phoffman183
Chattanooga, TN
16 GTI SE
Well, it aint! ;)
So I logged some more 3rd gear pulls in Map 6, 1 & 0 with the boost safety set @ 30 psi so it wouldn't switch to the safety map.
In map 6 the requested boost was 25-26 psi and actual boost was 15-16 (limited by map 6)
In map 1 the requested boost was 23-24 psi and actual boost was 27-28 (4 psi added by map 1)
In map 0 the requested boost was 24-25 psi and actual boost was 24-25 (No boost added by map 0)
So based on this info my ECU is definitely tuned. Now I just need to find out by who and what stage.
https://datazap.me/u/phoffman183/log-1623411438?log=0&data=1-2-4-23
phoffman183
Chattanooga, TN
16 GTI SE
Looks like Stage 1 or 1+. I'd start with APR, then Unitronic.
I just received confirmation from APR, I guess I need to work on a stacked Map 6 tune. This explains why the car seemed much faster than my previous MK6 GLI!
Your vehicle was tuned by us on 05/29/19 by New German Performance Nova to a stage 1 tune on 93 octane.
shovelhd
Western MA
Or sell the JB4, enjoy your 1+, and spend the money on other stuff like tires, wheels, sway bar, etc.
