Diggs24
de plains! de plains!
2015 GTI
I have an interesting twist. Using map 1, I had a few minor timing corrections, but using Map6 (tweaked), I am getting BETTER performance (and more linear which I prefer), AND no timing pull!
So wouldn't that be better to use instead of map1? Of course I would have to run it in the heat again, to make sure that I am maintaining no timing pull (I would rather have a cushion of safety).
Here is the Map6:
https://datazap.me/u/up4speed/log-1611027498?log=0&data=1-3-4-5-11-25-26-27-28
Here is Map1:
https://datazap.me/u/up4speed/map1?log=0&data=1-4-25-26-27-28
Thoughts?
Looks good, go for it.
dynamisoz
USA NJ
Daser Drives
Bahrain
VW Golf GTI 2018
Whatsup VW brothers!
I recently got jb4 on my stock mk7.5 gti 2018 manual (only k&n filter) and i have run some logs (3rd gear WOT) on, map2 and 3 for once and for the rest time i am using map0 until evrything seems to be clear, feel free to have a look of logs (screenshot) in attachments
Please let me know your suggestion on logs and maps which is the best for dailykeeping in mind i have manual clutch also am worried about AFR running abit lean running around 12.5-13.5
dmsyr
New Mexico
Dyno'd my car with my custom map6 settings. Made 325hp and 363tq. Mods are BMS Elite Intake system with turbo inlet, catless downpipe and 4 gallons of e85 topped off with 91. I was surprised by numbers. Those are pretty good, right fellas?
Daser Drives
Bahrain
VW Golf GTI 2018
325whp? if yes thats really good numbers and which dyno?
If that's on an IS20 yes that's excellent numbers.
dmsyr
New Mexico
Dynojet. I also found out afterwards the numbers were not corrected for high altitude (5000ft+). Not sure how that affects anything, if anything.
