Diggs24
- de plains! de plains!
- 2015 GTI
The wrong one.Which wire did you tap?
So tried some rs3 coilpacks to try and solve my high rpm misfire so I can actually start stacking. Anyone ever seen this?
Where they cheap chinese coils sold as "Designed based on the the high output ignition coils found on the 2.5T Audi RS3" becuse that is probably what they are.So tried some rs3 coilpacks to try and solve my high rpm misfire so I can actually start stacking. Anyone ever seen this?
Sure, looks good you can raise FOL to 50 if you want.Here's the newest log. Is this a good start to send to George?
https://datazap.me/u/gptuners/log-1600799189?log=0&data=1-2-3-4-11-18-19
Thanks!Sure, looks good you can raise FOL to 50 if you want.
Those aren't RS3 coil packs?
Gang, first post here, hoping for some help and advice on map 6 settings. Please and thanks in advance! 2015 GTI S PP DSG, 4th gear pull (on the dyno), 60F sunny day, Map 2 on 93 octane, and the mods are simply a drop-in filter, CTS Turbo inlet pipe and GFB diverter valve, IIRC. I'm not really sure what setting to safely change, and power looks a bit lower than I hoped. What do you all think? Again, thanks for the insight.
