Diggs24
- de plains! de plains!
- 2015 GTI
Looks great.
I bought 3 5 gallon tanks and then a 1/2 tank, when I have to fill up normally we shall see how long it last. I have about 2.5 gal left and just filled up. Went at the start of lockdown
yeah then its just not gonna work, the closest place to me was like 40 min away so we shall see how long I last mixing when I actually have to drive to my job during the weekThat would last me about two weeks. Not feasible. An intercooler makes much more sense. Either that or quit my job, buy a gas station, and install my own E85 pump. Better yet, open a distillery and make my own.
Are you running E- blend? If not you should since we have it everywhere in Sweden. I could run up to E35 with stock DP, 7psi add and FOL 60 without hitting trim limit.
Not sure how the OPF cars will respond so start at E25-30, I usually calculate E10 for petrol and E90 for E85 since E85 usually tests around 90% atleast here in the southeast.
Only tested E85 this year, local OKQ8 was 91% and Ingo 93% but last year I tested E5 95ron to 8-9%. I run E40 now on custom stage 2 mixing with 95ron because the closest station is unmanned without 98ron but I doubt I would notice any difference.Yeah I'm running 98 plus E85 around E25-E30. My station says E5 on the tap for 98. I usually put around 13 litres of E85 and fill up the rest with 98 when I refuel. Tank is 55 l. Car being Cupra and same engine as Golf R / S3 it likes FOL at 40.
Map is running 7 psi max, ran it at 7.5 at 4500-6000 without issues and was logging with George but backed off a little myself when I had issues, might bump it up again. Stock DP, just intake, hose, turbo elbow.
South of Sweden here too.
Actually OKQ8s 95ron is good enough to run US93 tunes on, they where servicing the E85 tank once this winter so could only get petrol but it did not knock at all but when I tried Qstar 95 I got 1-2 degrees knock on a couple of cylinders so quickly added some Ethanol.
Tjena pröva att gå tillbaka till 60/85/5 mjukvaran, JB4an begär för lite laddtryck så den lägger inte på lika mycket som den borde. Har sett flera lustiga beteenden på dom 2 sista versionerna som jag inte hade på 6b eller 85.
Looks ok, the 85 firmware is the first under 60 VAG gen 3 in this link. There is also a new 88 firmware that is supposed to fix the ecu_psi issue.Downgraded the firmware yesterday to 6b. Could not really determine which version 85 is? I'm having a hard time following the different versions and the naming scheme.
First pull:
https://datazap.me/u/callekl/clutch...0&data=1-2-3-4-5-6-11-14-18-19-25-26-27-28-29
Second pull upphill:
Full tank of 98RON with about ~9-10L of E85.
Just run map2 and see what it does. Leave firmware alone if it is working for you.
