JB1 vs JB4 Dyno Data
lamb110
Elburn, IL
Here is the results of my JB1 vs JB4 comparison. As you can see I didnt make much more power. I'm having an issue with the car pulling timing higher up in the rev range. All runs in 4th gear so the RPM is limited due to the speed limiter.
The JB1 dyno was done back in November running 93oct and Map 6 with a few tweaks by George:
For the JB4 dyno I was more prepared. I brought my laptop and had my mechanic log AFR from the exhaust so there is ALOT more data if you're into that. The first run was on Map 6, again with a few tweaks from George, I cant remember exactly what we changed after I installed the JB4 upgraded kit.
Run 1, Map 6:
Run 2, Map 2:
You guys have any idea whats causing the timing pull? I looked back at all my logs, even the JB1 ones that I sent to George and there is alot of timing being pulled in most of them higher up in the rev range.
0bLiViOuS
Orange County
I don't see any pull. I see timing advance which is ignition 1. You want that high in the rev range :) for a Mustang dyno, those are really good numbers! Especially if you consider it's not to redline and would make more
If you switch to the pro/advanced view (forget name) you can see all the other parameters like the pull and IATs. If you send us a screenshot of that, we can see it better
themyst
NYC
Nice peak numbers!
I am wondering what we can do to sustain peak power throughout more of the powerband like the flash tunes, you typically see max power sustained from 4500 and taper off up top. hard to make an apples to apples comparison though because of that annoying governor.
0bLiViOuS
Orange County
All tunes pretty much seem to taper around 5000rpm. Just a limitation of the turbo and is why the IS38 holds much more up top
oorrllyy
Honolulu, HI
What are your mods? 10whp is not bad for an additional $50 JB4 upgrade.
I did 262whp/316ftlbs with NPM in 3rd gear. Haven't dyno'd with the JB4 yet but if feels far better than the NPM.
TwinDad
Fort Lee, NJ
Seems like your leaving some torque on the table with your map 6. You can probably get more across the lower range. Also, why not a third gear pull so you could get peak hp?
Ricked_Em
STL
Our 4th gear are a 1:1 ratio and give the best possible numbers minus the governor thing.
Venumous
NE
291whp on a Mustang Dyno at only 21psi target at only 5500RPM? I'd say that is pretty damn good.
oorrllyy
Honolulu, HI
^^^he's right! I failed to realize it's a mustang dyno sheet. You can probably add about 12% to those numbers (or so I read) for similar dyno jet numbers
lamb110
Elburn, IL
Map6 Pro View:
Map2 Pro View:
My mods are just a CTS catless downpipe and CTS Intake, I put a Neuspeed IS38 Intercooler on last night but it wasnt on during the dyno.
oorrllyy
Honolulu, HI
Map6 Pro View:
Map2 Pro View:
Wow 14.6 target?? That absolute or additive? Looks like you're not hitting target if additive but way high if absolute. Not sure how that affects anything. Also, try adding ign 2-5 to see corrections.
Perry01
Hawaii and Utah
Nice dyno results!
If you include ignition 2, 3, 4, 5 you can see if there is any timing pull.
