2015 2 Door SE - Injen CAI with K&N filter, AWE Track Edition Catback, JB1
17,800 miles
About 15,000 with JB1
MAP 6 - 93 octane
Full throttle acceleration in 2nd through 5th I have experienced what appears to be clutch slip, 500-1000 RPM rise with slight acceleration loss, then settles in. Does not do it every time.
I recently set the JB1 to MAP 0 for stock testing. I did experience similar "slipping" but it was in 2nd gear a little over 2000 RPM.
I changed my MAP 6 settings to basically tune the slip out and it is better, but still a bit of slip on occasion. Not expecting to get my usual 200,000+ miles out of the clutch, just hoping it will last a while though. I generally do not drive it hard, and do not down shift when coming to a stop, I just put it in neutral and use the brakes to slow the car. I did have a MAJOR slip a week or so ago using a more aggressive MAP 6 than my current settings below. But it was a hard acceleration 1st to 2nd shift with traction control off (won't do that again). Chutch seems the same afterwards so not much damage was done.
Current MAP 6 settings:
RPM BOOST
1500 0.0
2000 0.5
2500 1.0
3000 1.5
3500 2.0
4000 3.0
4500 4.0
5000 5.0
5500 5.0
6000 4.5
6500 4.0
7000 3.5
