nok513
- Orange County, NY
- 2020 VW GTI S
After installing the brace, I've noticed a squeak coming from the rear. I was able to pinpoint the noise to the brake lines rubbing on the iSweep braces. It sounds like I had a case of water bottles in the trunk rubbing. Pushing the rear end up and down will reproduce the squeaking. I tried looking up if other people had this issue and came across Last Human's Garage video on youtube. I tried zip tying the lines and would only work for a short time. The squeaking back after a short drive and almost made it worse as the zip ties keep the line close to the brace.
I decided to try a cable sleeve in order to protect the line from rubbing and cutting down squeak. I bought the 1/4" sleeve [https://www.amazon.com/dp/B07FW5H57...abc_9BDNK5SK2M8D6SDRBJ2P?_encoding=UTF8&psc=1], which was perfect for passenger side, but just barely wraps around the driver side. I have cable ties on each end of the wrap to hold in place. After wrapping the lines, the squeak is gone. I will have to see if they will hold up, but so far a good solution.
