Half fast
- Jersey City
- Mk7 GTI
Wondering if there are any known issues with B16s and running extra camber.
When my car had about 90k on it, I installed a set of Bilstein PSS10 B16s. After about 10k, I installed the 034 camber plates and ~15k or so later (25k total) the front struts failed. I ended up purchasing and installing new B16 struts (was the best option available to me with a track date coming up at the time) and, with the new struts, I swapped over to Superpro camber plates. 5k later, it seems the drivers strut is now on the way out.
I know I'm not the only person out there running Bilsteins with extra camber (I've done it in the past on other cars) and I can't find anything that suggests this is a common issue, other than one person who was selling a set of coilovers after the shaft broke when installed with the 034 density mounts (the stiffer ones that don't have any extra camber). I also have the RS3 style solid rubber bushings, 26mm H&R FSB and run slicks on the track, so there's other stiffer front suspension work, but nothing crazier than what many other people run.
One of the old struts has a dark spot on the shaft. I've also not had any luck looking for causes of that, but I suppose it is possible that excessive heat from the brakes (both failures have come after a track weekend) could be causing the failure. Trying to google "dark spot on strut/shock shaft" just returns a bunch of results for "dark spot on shaft" which are unhelpful (though I suppose a reason to be optimistic, because at least I don't have that particular problem).
