IS38 VCDS LOGS
dwvw
I think I have some.
dwvw
VWGTI
A little off topic, but does anyone know where I can learn to read these logs? I'm sort of new to all this data logging things and I'm not quite sure how to read these.
ryansmk6
stuart, fl
Not sure to be honest, might just want to read up on tuning to help understand. I have a good friend that is pretty involved with tuning subarus that has helped me understand most of this stuff.
0bLiViOuS
Orange County
There are so many values it's hard to write down, but maybe we should put something together on the important areas.
Specified boost = what ECU is trying to hit
Actual boost = measured boost at MAP sensor
Timing correction = degrees of correction applied. You want to stay under 3-5 I believe is the consensus. I stick to 3
IAT = Intake air yemp... Lower the better
Lambda = a/f ratio.. Not sure 100% how to read this. I believe 1.00 is equal to 14.7 (stoich) and to calculate a/f you multiple value by 14.7 (i.e. 0.9 = ~13.2)
I think these are the key values you will want to know but there are so many really. Anyone please chime in if I'm wrong on any of these values and what they represent
AZGTI2
Phoenix, AZ
I have and am doing more at the request of APR.
