SilverMK7
- United States
- MK7 GTI
Hey all, I'm in a bit of situation and am looking for some direction.
Based on the title you can see I've upgraded to an IS38. My IS20 blew so I figured this was the time to do a swap. I tried sneekytuned but their file was malicious, it wouldn't allow my mechanic or I to read live data from either OBD11 or his VCDS which I found very strange. As soon as I installed the Cobb OTS IS38 tune it was fine. We finally were able to set the wastegate voltage correctly but I'm getting an EPC light that is instant even before the car is started. We tested the entire wiring harness, everything checks out. I ended up having to drive the car home which is 2 hours from his shop. The EPC light was on but I had 16lbs of boost even in limp mode the whole way home.. We are completely stumped other than thinking the wastegate is faulty out of the box. I've listed the VCDS results below. Has anyone encountered an issue like this? Thank you in advance.
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VWTT7AUXFM032147 Mileage: 117492km-73006miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
75-Telematics -- Status: OK 0000
Address 01: Engine (J623-CXCA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0005
Revision: --H13---
Coding: 091D00124424002F0000
Shop #: WSC 00066 790 00221
ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: 2C57D85547B47BEB4F-8078
1 Fault Found:
14849 - Boost Pressure Control Valve/Solenoid (Bank 1)
P0045 00 [167] - Open Circuit
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 117492 km
Date: 2021.05.22
Time: 18:25:48
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 32 °C
Intake air temperature: 30 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.363 V
Unlearning counter according OBD: 40
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000000
Charge air pressure control valve uncond voltage sensor: 3.5986 V
Charge air pressure control valve position: target value: 0.00 %
Charge air pressure control valve position: actual value: 0.00 %
Charge air pressure control valve activation pulse duty factor: 0.00 %
Charge air pressure control valve voltage: position closed: 3.4593 V
STATE_BPA[0]: OPM
Readiness: 1110 1101
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 041 T HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4511
Revision: 03253104 Serial number: TFK01407132648
Coding: 0014
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 2959214148466EC3B4-807C
No fault code found.
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 52154000000240
Coding: 01FA6BA13423096E0078020481CA2980D62C9000408194B400430050C009
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033.rod
VCID: 448790F5CF2493ABA7-8010
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 R HW: 5G0 907 426 R
Component: AC Manuell H02 0907
Revision: 00001K06
Coding: 00020004200100000000000000000000
ASAM Dataset: EV_ACManueBHBVW37X 003019
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 3A7BEE0DBDE0D55BCD-806E
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 N HW: 5Q0 937 087 N
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86582808141135
Coding: 000018464001804969644000001407201000000000000000000000000000
Shop #: WSC 00066 790 00224
ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
ROD: EV_BCMBOSCH_013.rod
VCID: 46838AFDF918A1BBB9-8012
Wiper motor control module:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 140709 043 0581
Serial number: 140912073622
Coding: 0E4DDD
1 Fault Found:
329480 - Heated Passenger Seat
B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 240
Mileage: 117492 km
Date: 2021.05.22
Time: 18:01:07
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM00WHWG
Coding: 8CCCFC00000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 51A9A9A1005676031C-8004
Seat occupied recognition passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. H05 0016
Serial number: IBH0000J1400019VWM0-
Coding: 30325A
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: ----------- HW: 480 001 407 14
Component: SideSensor_Df 001 0887
Serial number: 35700000000F6459401G
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: ----------- HW: 480 002 407 14
Component: SideSensor_Pf 001 0887
Serial number: 3580000000043048A013
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: ----------- HW: 480 400 108 14
Component: SideSensor_Dr 001 6149
Serial number: 3510002C316DB80042A
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: ----------- HW: 480 400 108 14
Component: SideSensor_Pr 001 6149
Serial number: 3520002BF16DB805111%
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 207 14
Component: FrontSensor_D 001 6149
Serial number: 35500029D1656902C3E9
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 207 14
Component: FrontSensor_P 001 6149
Serial number: 3560002B3165690540BY
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20140717400096
Coding: 0410
Shop #: WSC 66564 385 16448
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F8D9F19A6C2F073FA-806A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 856 HW: 5G1 920 856
Component: KOMBI 342 4270
Coding: 0BBD010A2180CF0502086A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009037
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 6BD51B49823ABCD306-803E
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 S HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2186
Revision: -------- Serial number: 15081410001014
Coding: 0101000820085900EF0000281C0F00000001050000000000000000000000
Shop #: WSC 00066 790 00199
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
VCID: 418999E1D03686838C-8014
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0101
Serial number: 29140001470500054292
Coding: 29FFFF
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 020914060502NS
Coding: 003E03200000040100000000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 408F9CE5DB3C8F8B83-8014
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8102
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 3561FD3194FE3A2320-8060
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 27081406050GLE
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0645
Serial number: V7B00308143042
Coding: 02730000FF00000021220001001800001F0203040100010002
ASAM Dataset: EV_MUStd4CPASE 002040
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 64C770756FE4F3AB47-8030
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS500K42
1 Fault Found:
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 200
Mileage: 117492 km
Date: 2021.05.22
Time: 17:36:14
Voltage terminal 30: 12.8 V
Satellite radio tuner status-Satellite radio antenna status: electrically OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 HW: 5QE 035 285
Component: OCULowMQBUS 006 0528
Coding: 02730002C28218017F1E06000000
Shop #: WSC 00066 790 00122
ASAM Dataset: EV_OCULowMQB 001003
ROD: EV_OCULowMQB.rod
VCID: 020B56ED95B05D9BD5-8056
1 Fault Found:
2103041 - Control Module
B1788 F0 [009] - Start Prohibition Deactivated
Freeze Frame:
Fault Priority: 8
Fault Frequency: 1
Reset counter: 200
Date: 2000.00.00
Time: 00:00:00
Revision: --H13---
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 117492 km
Date: 2021.05.22
Time: 18:25:48
STATE_BPA[0]: OPM
Coding: 0014
Revision: 00001K06
Coding: 0E4DDD
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 240
Mileage: 117492 km
Date: 2021.05.22
Time: 18:01:07
Coding: 30325A
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 0410
Generator:
Coding: 29FFFF
Coding: 8102
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 200
Mileage: 117492 km
Date: 2021.05.22
Time: 17:36:14
1 Fault Found:
Freeze Frame:
Fault Priority: 8
Fault Frequency: 1
Reset counter: 200
Date: 2000.00.00
Time: 00:00:00
